Hey motomack,
I filled up the transmission, after idling for 20 min, and got it up to full in the hot section of the dipstick. Still no movement and I didn't see any leaks...what should I try next?
Hey basscatt,
Here are my codes and definitions (and other info the dash says):
PCM P0101 HISTORY DTC P0101 Mass Air Flow (MAF) Sensor Performance
PCM P0440 CURRENT DTC P0440 Evaporative Emission (EVAP) System
PCM P0452 HISTORY DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
PCM P0453 CURRENT DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
PCM P0601 HISTORY DTC P0601 Control Module Read Only Memory (ROM)
PCM P0621 HISTORY DTC P0621 Generator Lterminal Circuit
PCM P0622 HISTORY DTC P0622 Generator Fterminal Circuit
PCM P0741 CURRENT DTC P0741 TCC System Stuck Off
PCM P1106 HISTORY DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
PCM P1189 HISTORY DTC P1189 Engine Oil Pressure (EOP) Switch Circuit
PCM P1441 HISTORY DTC P1441 Evaporative Emission (EVAP) System Flow During NonPurge
PCM P1545 CURRENT DTC P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
PCM U1064 HISTORY DTC U1064 Loss of Communications with DIM
PCM U1152 HISTORY DTC U1152 Loss Of ACM Serial Data Communication
IPC B2710 HISTORY DTC B2710 PASSKey Open/Shorted Pellet
ACM B1314 HISTORY DTC B1314 Evaporator Inlet Temp Sensor Open CKT
ACM U1153 HISTORY DTC U1153 Loss of Communications with CCP
NO SDM CODES
TCS C1211 HISTORY DTC C1211 ABS Indicator Lamp Circuit Malfunction
TCS C1234 CURRENT DTC C1234 LR Wheel Speed Circuit Open or Shorted
TCS C1242 CURRENT DTC C1242 Pump Motor Circuit Open
TCS C1282 HISTORY DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
NO PZM CODES
NO IRC DATA
RFA U1000 HISTORY DTC U1000 Class 2 Communication Malfunction
NO CCP CODES
MSM B2108 HISTORY DTC B2108 Front Vertical Up Switch Failed
MSM B2107 HISTORY DTC B2107 Front Vertical Down Switch Failed
MSM B2106 HISTORY DTC B2106 Horizontal Forward Switch Failed
MSM B2105 HISTORY DTC B2105 Horizontal Aft Switch Failed
MSM B2104 HISTORY DTC B2104 Rear Vertical Up Switch Failed
MSM B2103 HISTORY DTC B2103 Rear Vertical Down Switch Failed
MSM B2102 HISTORY DTC B2102 Recline Forward Switch Failed
MSM B2101 HISTORY DTC B2101 Recline Aft Switch Failed
MSM B2110 HISTORY DTC B2110 Lumbar Forward Switch Failed
MSM B2120 CURRENT DTC B2120 Lumbar Up/Down Sensor Failed
MSM B0856 HISTORY DTC B0856 Battery 2 Out of Range
MSM B1982 HISTORY DTC B1982 Device Power Circuit High
MSM B1983 HISTORY DTC B1983 Device Power Circuit Low
MSM U1300 HISTORY DTC U1300 Class 2 Short to Ground
NO MMM CODES
SERV STABILITY SYS
CHECK GAS CAP
APPLY BRAKE TO SHIFT
ICE POSSIBLE
LOW RANGE
11.4 MPG AVG
0 MPG INST
82.1 GAL FUEL USED
14.6 AVG MPH
TIMER OFF 00:00:00
13.9 BATTERY VOLTS
73% OIL LIFE LEFT
ENGLISH/METRIC RESET
ODOMETER: 133844
I don't know if this matters, but I put in a new radio and cigarette lighters a week before this problem with the transmission...
nice job of posting codes WITH THEIR DEFINITIONS -
AND including Current or History -
that really helps us help you - :highfive:
the only trans-related code - P0741 - isn't the cause -
so I'd say something actually broke inside the trans -
figure $2500 to $3500 to completely rebuild it -
the next question is usually -
what about putting a used trans in it -
a used trans is a real crap shoot -
it will cost at least half what a rebuild would cost -
it might work perfectly for 100,000 miles -
or - it might fail 100 feet after installed -
as for all the other codes -
I would recommend clearing them all -
and see what comes back -
after getting the trans fixed of course -
