so my deville with 70k starts acting up on drive home from work Saturday. Its running pretty damn rough and seems to only smooth out while doing 60mph. where should i start? i checked front plugs (replaced all about 20k ago), all sensors, egr, etc. should i pull off the injectors one by one?
1997 Eldorado, 2003 Audi RS6
Did you replace your wires too? What year Deville? Could be crank position sensor, oxygen sensor, MAF, EGR. If it is that rough, you will get a Service Engine light soon. Read the code.
Injectors are the last thing I would suspect. I'd concentrate on the plugs, coils and ICM connectors.
