1994 FWB Optispark replaced , and won't start
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By jayoldschool
  • 1 Post By soy_chingon13
1985-1996 Fleetwood and Brougham Forum Discussion, 1994 FWB Optispark replaced , and won't start in Past Cadillac Vehicle Discussion; My 1994 Cadillac Fleetwood Brougham ran fine , found it leaking slowly out of my water pump. So ordered a ...
    Patroll is offline Cadillac Owners Member
    Dec 2018
    15
    My 1994 Cadillac Fleetwood Brougham ran fine , found it leaking slowly out of my water pump. So ordered a water pump ,Optispark, and a harmonic balancer . replaced all the parts and it wouldn't start. I left it alone came back my son had started it , and drove it about 30 feet so we could flush out the radiator, via heater hose line. We did have a small leak around the thermostat hosing ,because I removed it for my first flushing, drained the water added radiator flush and was started with flush you buy , was going to put a few miles on it flush it again . Then wash it out , fill with antifreeze. PROBLEM : car just shut off and want start, its more than likely the spark , or the new cheap Optispark any help here? May have gotten a small amount of water on it, but not a lot. A little water shouldn't affect it , because a big puddle could do worse.Any tips maybe try to see if I'm getting fire?
    jayoldschool's Avatar
    jayoldschool is offline Super Moderator
    Automobile(s): 2011 CTS SportWagon
    Sep 2006
    Ontario, Canada
    46
    9,308
    Re: Optispark replaced , and want start
    Cheap optis are a known bad spot. Take it off, put the old one back on. Do a cap and rotor if you want, or, just open it and clean it. Likely zero coolant in it, it's a sealed unit. My water pump leaked on my opti for two years before the pump bearing blew all the bearings out the back. Had to change it then, lol. Opti still works fine, 15 years later.
    silverfox103 likes this.
    Dec 2018
    15
    Well tested it and has no spark, I did notice the 4 wire connector was severely twisted going to the ignition control module by the coil .With the two inner wires showing . Will check continuity to see if they are touching inside . Yes ran fine, bought a cheap $50.00 one off eBay, because doing the water pump and opened a can of worms . Probably got a bad one.
  5. #4
    soy_chingon13's Avatar
    soy_chingon13 is online now Cadillac Owners Fanatic
    Automobile(s): 1996 Fleetwood
    Jan 2005
    Chandler, AZ
    467
    $50 Opti?
    Sent from my SM-G965U using Tapatalk
  6. #5
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Enthusiast
    Automobile(s): 96 Fleetwood, 07 CTS, & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    70
    552
    I hope you really didn't expect a $50 Opti to do the job? Do what Jay said.
    Tom
  7. #6
    Dec 2018
    15
    Re: 1994 FWB Optispark replaced , and won't start
    Well here's the verdict . I removed the new China made Optispark , and noticed the plastic cover/plate under the rotor button had a small crack in it allowing a spark to shot thru it. It had a grayish/black residue on that crack. . So gentleman , I put to new O-rings on the shaft and got a new cap and rotor button and listened to Joe. Thanks my friends on here.
Read about Lincoln | Buick | Genesis | Kia Forte Forum
