Can HG be blown or leaking and not overheat?
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Can HG be blown or leaking and not overheat? in Cadillac Engine Discussion; Odd coolant behavior, but never overheats. -->...
    blackx70 is offline Cadillac Owners Member
    Automobile(s): 2003 Deville Base
    Aug 2018
    Florida
    3
    1969byrdman's Avatar
    1969byrdman is online now US Coast Guard: Semper Paratus
    Automobile(s): 2003 DeVille base, 148K miles
    May 2014
    Van Zandt County, Texas
    71
    3,758
    Re: Can HG be blown or leaking and not overheat?
    what is odd about it? Have you checked for flow through the surge tank? have you done a block test to see if HG is blown?
    Have you checked codes?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,885
    Welcome Aboard !!!
    What odd coolant behavior ?? Describe your symptoms exactly, please.
    As posted - purge line, cylinder block exhaust gas test, and water pump -drive tensioner pulley, coolant level sensor, correct coolant level, cooling system checks, pressure cap leaking - sure an engine can have a blown head gasket and not overheat.
    One cause of Northstar overheat because the cylinder block head bolt hole threads fail, the bolt(s) loosen, exhaust gas blows past the fire ring, eats the soft gasket material, over-pressurizes the cooling system, blows off coolant, the engine overheats.
    Other causes are cracked surge tank, rusted heater piping at the firewall, rusted thermostat housing, faulty water pump, improper heater circuit flow, etc..
    The Engines; Northstar forum - sticky threads on cooling system problems.
  5. #4
    Aug 2018
    Florida
    3
    Was losing coolant via overflow. Replaced cap and has stopped, though I check it daily. No codes, no overheat, have not block tested. Purge line flows, replaced water pump belt and tensioner and I replaced the thermostat when we first got it.
  6. #5
    Feb 2006
    79
    64,885
    You should be good to go.
    Click my username, open the profile. Left column, scroll to Albums - 3 albums of stuff for your Northstar.
    The ticks on your temp gauge - and the fan settings - are the same as mine. Coolant surge tank about half full, cold.
  7. #6
    71
    85,735
    He has a base Deville. Digidash, no analogue gauges.
  8. #7
    Feb 2006
    79
    64,885
    Ah, so ........ Then the center "bar" on the temp indicator = the 12 o'clock range on my picture. Each solid tick that appears corresponds to the same ticks on the analog gauge.
    Both panels use the same coolant temp sender.
  9. #8
    Aug 2018
    Florida
    3
    Thank you very much.
  10. #9
    Ameierot's Avatar
    Ameierot is offline Cadillac Owners Member
    Automobile(s): 1996 Sedan Deville 117K
    Feb 2019
    Iowa
    52
    23
    On the same topic, would a very small piece or two of what appears to be gray 'foam' material floating in the surge tank constitute some of that 'Soft gasket material' that Sub mentions a few posts up?.....Incidentally, I'm trailering my 1996 Deville to Palatine, IL tomorrow to have the engine inserted, etc. based exclusively on the recommendations of this group. Undeniable evidence of HG failure in my case. I'll let you guys know how everything turns out.
  11. #10
    Feb 2006
    79
    64,885
    Maybe - maybe ......... but that "soft gasket material" is actually a mat of graphite, fiber, organic material and sometimes extremely fine wire screen.
    Surf through the stickies on head gasket troubles at the top of this Northstar main threads page - plenty of photo history of the erosion of the edges of coolant passage holes in gasket material.
    Note that NO gasket material is missing from between clamped surfaces - only chips/chunks at the open deck areas or hole edges. Normal in ANY engine head gasket with coolant passage slots/holes.
    See those curved slots and other holes with a "rusty" look? Those exposed coolant passage edges are subject to erosion in ANY engine and are NOT, in any way, contributory to "head gasket failure" due to failed cylinder block head bolt hole threads.
    The cylinder (gas pressure) edges are sealed by the collapsible stainless steel fire rings.
Similar Threads
  1. Blown HG - exhaust in coolant - how long can I drive it?
    By CorgiCaddy in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 07-06-15, 09:24 PM
  2. I'm back, after CCC studs installed two years ago a blown HG and loose stud WTH?
    By Manic Mechanic in forum Northstar Engines and System Technical Discussion
    Last Post: 06-25-15, 10:15 PM
  3. Hg or not the hg....that is the question
    By 98eldo32v in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-19-10, 01:44 AM
  4. Blown Hg At 53,000 Miles
    By STS 99 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 11-21-07, 11:36 AM
  5. UPDATE 2000 DTS Blown HG's Now eletrical issues??
    By mrmadhead in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 06-13-07, 09:05 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
