Olds LX5 Shortstar head gasket issues?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Olds LX5 Shortstar head gasket issues? in Cadillac Engine Discussion; I have a co-worker with an 01 Olds Intrigue with the Shortstar and he thinks it has head gasket issues. ...
    LsGsSTS's Avatar
    LsGsSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 STS V-8 1SF Magneride HUD/ACC
    Jan 2017
    U.P. of MI MGOBLUE!
    56
    1,259
    I have a co-worker with an 01 Olds Intrigue with the Shortstar and he thinks it has head gasket issues. Did this engine have the same issue with heads lifting that the N* had, or was it different enough to have "simple" head gasket problems? I told him I would ask here as the wealth of knowledge on this forum surpasses about any other forum I've been on - and that's a lot!
    71
    85,670
    Re: Olds LX5 Shortstar head gasket issues?
    Not getting much info on this site from "short star" owners, but my guess is it was the same. I'd do a block test and if it fails, treat it the same as the Northstar, that is, drill and insert or stud the bolt holes.
    LsGsSTS's Avatar
    Jan 2017
    U.P. of MI MGOBLUE!
    56
    1,259
    Well if you can believe Wikipedia, although it's "based" on the Aurora, the block was 100% new which is why I wonder if it suffered the same problems.
Similar Threads
  1. L37, ld8, l47 & lx5
    By Cadillackostab in forum Northstar Engines and System Technical Discussion
    Last Post: 10-09-11, 02:16 PM
  2. ShortStar 3.5L oil usage
    By bsandnes in forum Northstar Engines and System Technical Discussion
    Last Post: 01-21-08, 07:19 PM
  3. How is GM doing VVT on the ShortStar and NorthStar?
    By N0DIH in forum Community Lounge, Introductions and General Discussion
    Last Post: 03-05-07, 08:58 AM
  4. 3.5L Shortstar Ignition
    By CTX-SLPR in forum Northstar Engines and System Technical Discussion
    Last Post: 04-21-06, 03:29 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
