4.5 oil pan removal
Results 1 to 4 of 4
HT4100 4.1, 4.5, 4.9 Discussion, 4.5 oil pan removal in Cadillac Engine Discussion; I am trying to bypass a big bill at the auto repair garage by changing my oil pan gasket myself. ...
    acree25 is offline Cadillac Owners Member
    Oct 2003
    18
    4.5 oil pan removal
    I am trying to bypass a big bill at the auto repair garage by changing my oil pan gasket myself. It leaves a little puddle of oil every time I drive it. I tried removing it by myself and followed the procedure in the repair manual. After I removed the bolts from the pan, I noticed that the pan would'nt come off. I then tried hitting it with a rubber mallet, and still nothing. There is hardly any room to pry it off, and It is sealed on there pretty tight.
    One shop told me that they would have to lift the engine up before removing the oil pan, but the manual didn't say anything about that.
    Does anyone have any tricks or suggestions to get that thing off of there?
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: 4.5 oil pan removal
    IN my FSM, there is a special tool used to break the seal in between the block and the gasket/pan.... You might be able to rent one.....
    It looks like a putty knife bent at a 90* angle...... WIth metal block on one side to allow you to hit it with a hammer!
    Oct 2003
    18
    Quote Originally Posted by elwesso
    Thanks for the info, Elwesso! That should help a great deal. I am going to o look around for a tool like that today. I tell you how it goes. That sounds like it would work pretty well.
  5. #4
    aspetras's Avatar
    aspetras is offline Cadillac Owners Member
    Automobile(s): 93 Eldorado 4.9
    Apr 2019
    Czech Republic
    11
    It helped? I have a similar problem. I've already cut off the exhaust. I've got it almost out, but it always sticks to the flywheel cover and doesn't go out.
    Is there some video tutorial somewhere? I found nothing :-(
Read about Lincoln | Buick | Genesis | Kia Forte Forum
