Error code p0456?????
Results 1 to 3 of 3
Cadillac XTS Forum Discussion, Error code p0456????? in Current Cadillac Vehicle Discussion; My 2014 XTS was giving me the P0171 error code. I was told that I was in need of an ...
    twanlo456 is offline Cadillac Owners Member
    Automobile(s): '14 XTS Luxury AWD
    May 2018
    Washington, D.C.
    4
    My 2014 XTS was giving me the P0171 error code. I was told that I was in need of an Mass Flow Sensor. I changed the sensor with a OEM AC Delco sensor. Check engine light remains, now I’m getting code P0456 (EVAP) issues I guess. Can anyone provide in hits or tips to fix this situation? Thanks in advance for any and all replies!
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,650
    Re: Error code p0456?????
    Take out a multi-year subscription to www.alldatadiy.com - it's the online version of the GM/Cadillac service manuals for your car. When you open the home page there's a menu on the left side. At the top is "Diagnostic Trouble Codes". Scroll down to your problem code, click it, and it opens a system description, problems, and diagnostic trees.
    P 0171 is a lean mixture, left bank. Usually a vacuum leak, not the MAF. Diagnose the problem instead of throwing parts at it.
    P 0456 is a small EVAP leak - gas cap, fill pipe, tank hosing, charcoal canister, EVAP purge solenoid, EVAP test port (capped with a green valve cap) - near the throttlebody, black plastic pipe.
    EVAP stores fuel tank vapor from expansion and burns it during highway steady speed running.
    https://obdii.pro/en/model/gm
    Ken4 is offline Cadillac Owners Member
    Automobile(s): 2016 XTS platinum
    Mar 2019
    Eastern Tennessee, USA.
    17
    I had a small EVAP leak that came and went on another GM car that I had. Turned out to be the tank seal for the fuel tank and sending unit. They used a machine that makes some kind of smoke to find the leak. They told me that this seal is the problem a lot when it is not the obvious.
Similar Threads
  1. Turning off ERROR: "Shift To Park" error..... HELP!!!
    By freshchops in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 11-18-17, 09:48 AM
  2. p0151 p0174 p0175 p0456 help
    By Fuddy1409 in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 03-10-17, 04:33 PM
  3. ECM error code 30 ISC Fault / code 50 EGR sensor fault
    By ralphiedee in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 06-08-13, 03:48 PM
  4. Iphone App Multiple Error/Time Out/Duplicate Post and Other Error Messages
    By SUPER LAC DEVILLE in forum Community Lounge, Introductions and General Discussion
    Last Post: 03-05-13, 03:41 PM
  5. 96 Deville error code and display error help
    By gmin in forum Electrical Technical Information
    Last Post: 02-08-04, 03:37 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
