Bump when shifting
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By CWB
  • 1 Post By Jakerin
Cadillac STS-V Series Forum Discussion, Bump when shifting in Cadillac V-Series Forums; ...
    Jakerin's Avatar
    Jakerin is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2016
    Coarsegold, CA.
    470
    Bump when shifting
    I’m feeling and hearing more of a ‘bump’ when the tranny shifts than I should I think. It only happens when there is some slack in the driveline as when it shifts as I switch from S3 to D for example. Is there a bump stop built into the differential? Not just an external rubber stop but something built in?
    baller95's Avatar
    baller95 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac STS-V Black On Black
    Jun 2010
    Toronto, Canada
    28
    1,427
    Re: Bump when shifting
    Do a transmission oil change and reflash your trans tune. Should help!
    CWB
    CWB is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS 1SG HUD ACC F55 AWD, 08 STS 1SG Platinum HUD ACC F55 RWD
    Mar 2016
    Lower Alabama
    69
    230
    Put it on a lift. With a pry bar, try to move the nose (front) of the differential up. If it moves much at all, you have found your problem. Replace the front diff. bushing with factory or aftermarket ie. Creative Steel bushing.
    Jakerin likes this.
  5. #4
    Jakerin's Avatar
    Jul 2016
    Coarsegold, CA.
    470
    Dayum! Diff out and five hours labor!!! With 104,000 miles, anything else back there needed to be addressed? Still cheaper than car payments I guess.
  6. #5
    CWB
    Mar 2016
    Lower Alabama
    69
    230
    What problem did you find? The bushing problem does not require diff removal. Read up on this problem in this and the more populated STS forum. You will find some DIY writeups. Which replacement part you use affects the amount of disassembly required. Good Luck.
  7. #6
    Jakerin's Avatar
    Jul 2016
    Coarsegold, CA.
    470
    Haven’t had a mechanic look at it yet but now I’m concerned about which part to order if that’s the problem, the harder longer lasting CS unit or the OEM piece. The OEM bushing lasted 13 years and 104,000 miles and apparently has done its job, so I wouldn’t want a replacement bushing to transmit more noise than the OEM bushing.
  8. #7
    Rboughne1's Avatar
    Rboughne1 is online now Cadillac Owners Enthusiast
    Automobile(s): '06 STS-V, '17 CTS-V
    Jul 2014
    PA-NJ line
    765
    Quote Originally Posted by Jakerin View Post
    Nobody that went to the CS Urethane bushing complained about noise or vibration.
  9. #8
    mycaddy94 is offline Cadillac Owners Member
    Jul 2005
    Missoula, MT
    40
    15
    check your motor mounts!! I just had a similar thing, my driver side mount was broken
  10. #9
    Jakerin's Avatar
    Jul 2016
    Coarsegold, CA.
    470
    Kudos to Creative Steel. Ordered the bushing on Friday and it arrived Monday morning. $69.45 shipped. Decided on the dealer out of a dozen or so shops that weren’t interested, couldn’t or wouldn't do the job (and) the dealer got me in the morning after I called for an appointment. Spoke to the mechanic who wanted to see the bushing I brought, was impressed with it, had done the job before and had the necessary tool to boot! The labor estimate including new diff fluid was $895 and the total charged was $750. The old bushing was really shrunk. There were two one inch sections that I could see through to the other end. Thirteen years and 104,000+ miles really took their toll but now, the shifting, up or down is way better. More positive, no CLUNK from the rear on casual upshifts and downshifts are better too. Now, if I could only reach 25 mpg!
    carter's_sts likes this.
  11. #10
    Rboughne1's Avatar
    Jul 2014
    PA-NJ line
    765
    Now put in the Creative Steel motor mounts. Big difference. Not the solids, the urethane that give a bit. TIIIIIGHT.
  12. #11
    Jakerin's Avatar
    Jul 2016
    Coarsegold, CA.
    470
    Quote Originally Posted by Rboughne1 View Post
    Since mine are ok, what difference would there be? The only motor mounts I ever broke were on my 66 SS396. Not as much hp but I’m sure it weighed about twice as much as the tiny Northstar weighs.
Similar Threads
  1. Question about shifting, trouble shifting, double clutching, etc...
    By Zhariak in forum 2009-2015 Cadillac CTS-V General Discussion
    Last Post: 09-11-12, 10:26 AM
  2. mounts? tranny? Bump when shifting to "D" and so forth
    By Liz's CTS in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-18-11, 06:55 PM
  3. Transmission Shifting Question - Trouble Down Shifting
    By JBCTSV in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 09-12-10, 09:41 AM
  4. pics of the new bump bump
    By Acqua7 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 02-23-08, 01:50 PM
  5. Shifting "bump"? (currently test driving '98 SLS)
    By iametarq in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 02-02-05, 02:30 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
