2007 northstar light knocking noise
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By curtc
Cadillac STS Forum - 2005 through 2012 Discussion, 2007 northstar light knocking noise in Past Cadillac Vehicle Discussion; https://www.youtube.com/watch?v=CCegpHQydP8&t=56s https://www.youtube.com/watch?v=Q6xk28mivEA doesn't sound when cold, engine oil5w30 Mobil 200 000 kms, as strange it can be, the engine doesn't ...
    valjan is online now Cadillac Owners Member
    Automobile(s): 2007 STS N* and a 2003 Deville
    Sep 2016
    montréal, canada
    68
    13
    Cool 2007 northstar light knocking noise
    doesn't sound when cold, engine oil5w30 Mobil 200 000 kms, as strange it can be, the engine doesn't burn oil
    I've seen a few with this problem on youtube
    When i rev it around 12000 it seems to silence it. Could be the timing chain ?
    Or piston flap ?
    Feel free to reply
    These videos are before tightening
    Jgrade83 is offline Cadillac Owners Member
    Apr 2019
    Mine is doing the same damn thing.. I've taken it to the dealership 3 times with a p0171/p0174 codes, and they claim it's running fine.. I call BS.. I'm taking it to another local guy on Wednesday to Getting it figured out.
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    33
    6,316
    Re: 2007 northstar light knocking noise
    p0171/p0174 are lean codes - If this is a N* check the intake manifold bolts (update your description so we know what we're working on), they tend to loosen up. Recommended spec is 89 inch pounds I believe, hand tight is good. Don't over tighten or you risk cracking the manifold.
    valjan and Too Fast like this.
  5. #4
    Too Fast is offline Cadillac Owners Member
    Automobile(s): 2008 STS Northstar RWD, 2000 Trans Am WS6 6 spd, 1968 LeMans convertible 6.6
    Apr 2019
    Indianapolis
    31
    Damn! RE760 Sport summer performance tires I am jealous! I just put the last set of those available, on my WS6, March of 2019, in a 275/40-17 size. Anyway, that sound you shared sounds like nothing to be concerned about. It sounds like a valvetrain noise, but not an engine knock. My Northstar sounds similar.
  6. #5
    Sep 2016
    montréal, canada
    68
    13
    https://www.youtube.com/watch?v=jW4X1xMQew0
    After tightening intake manifold the bolts were so loose i could tighten them by hand.
    It silenced it be 80% thank you. We learn everyday.
    This video is after tightening intake
  7. #6
    Sep 2016
    montréal, canada
    68
    13
    Yes i like those RE760 but on wet not so much. I just tighten the intake manifold following an advice from curtcand it silenced it by 80%
    You should listen to both videos, before and after
  8. #7
    LsGsSTS's Avatar
    LsGsSTS is online now Cadillac Owners Connoisseur
    Automobile(s): 2005 STS V-8 1SF Magneride HUD/ACC
    Jan 2017
    U.P. of MI MGOBLUE!
    56
    1,284
    I've got RE11's on my convertible. The variable valve timing on this gen N* can be a little noisy. Nothing to worry about. Manifold tightening sequence:
Similar Threads
  1. 2007 Escalade Ext Engine Pinging/Knocking noise?
    By apollo18 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 01-17-14, 11:25 PM
  2. Knocking Northstar (Not on cold start)
    By boarder_punk in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-25-11, 07:13 PM
  3. 94 Northstar Flexplate knocking noice. HELP!!
    By Evita in forum Northstar Engines and System Technical Discussion
    Last Post: 01-15-08, 11:50 AM
  4. Knocking On My Northstar Engine 96 STS Sevile
    By DivineChaos in forum Northstar Engines and System Technical Discussion
    Last Post: 05-04-07, 07:37 PM
  5. 94 STS Northstar Knocking
    By barryr in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 06-18-06, 08:59 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
