MRC/passive suspension bypass resistors
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Cadillac STS Forum - 2005 through 2012 Discussion, MRC/passive suspension bypass resistors in Past Cadillac Vehicle Discussion; Hello everyone, im having this same issue but on "2005 STS v8" would (4.7 ohm, 1/2 watt) in connector level ...
    mrcoollv is offline Cadillac Owners Member
    Feb 2019
    28
    Hello everyone, im having this same issue but on "2005 STS v8" would (4.7 ohm, 1/2 watt) in connector level work the same for this model of car ?
    Quick reply to this message Reply
    basscatt's Avatar
    basscatt is online now Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,432
    Re: Code C1711 on 98 STS
    Quote Originally Posted by mrcoollv View Post
    the 2005 STS is NOT a Seville - you should try the STS forum - here -
    https://www.cadillacforums.com/forum...-through-2012/
    to answer your question - NO - the 4.7K ohm, 1/2 watt resistor trick only works on the F45 suspension system -
    I believe you have the F55 - MagnaRide system -
    that takes a 2 ohm 10 watt resistor - one for each strut/shock -
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,205
    ........ and it's 4.7K Ohm (4700 Ohm) 1/2 watt for F45 (CVRSS); 2 or 3 Ohm 5 or 10 Watt for F55 (MRC).
    The resistance values are very different and the power handling (Watts) is different due to the suspension control solenoid power usage at each strut/shock.
    I'll move these posts to STS and leave a note in the old dead thread in Seville.
  5. #4
    Feb 2019
    28
    thank you for moving post, ok i added t=an 2ohm 10watt and yet still getting the dash message and speed limited to 80.....
    any help will be great, thanks
  6. #5
    Feb 2006
    79
    65,205
    Re: MRC/passive suspension bypass resistors
    Perhaps your messages are for some other suspension fault.
    Did you install the resistors in the strut/shock pigtails or at the hub wheel speed sensors ?
    Take the car to a large parts store and ask them to scan it. Post the found codes and their definitions here.
  7. #6
    Feb 2019
    28
    Quote Originally Posted by Submariner409 View Post
    strut/shock elec tape then soldier once i see it working, i will stop by autozone today and do a check and post info thank you
  8. #7
    Feb 2019
    28
    not getting any suspension codes only the missing cats we removed this pass weekend p0420 bank1, po430 bank2
    im going to work on these codes first then jump on suspension again ..
  9. #8
    Feb 2019
    28
    Quote Originally Posted by basscatt View Post
    question, im still getting the message on dash when i added to the front only " 2 ohm 10 watt resistor " my guess is rear as well ?
  10. #9
    Sigma-V is offline Cadillac Owners Member
    Automobile(s): 2-2007 STS-Vs, 2005 STS4 1sg, 2004 SRX4, 2008 1sc
    Feb 2018
    North Mississippi
    22
    a light bulb (like the parking light bulb) can be connected across the mrc shock connector to simulate the proper resistance
  11. #10
    Feb 2019
    28
    Thumbs down 2005 STS v8 (suspension service + limited to 80mph)
    i had some suspension work done to active system and now need to trick the ECU
    on dash getting " (suspension service + limited to 80mph) " i added 4 2ohm 10watt per strut and didn't do the trick is there anything else needs to be done ?
  12. #11
    Feb 2019
    28
    created a new thread
    See Post #12. Sub.
  13. #12
    Feb 2019
    28
    Quote Originally Posted by Sigma-V View Post
    sorry i dont understand
  14. #13
    Feb 2006
    79
    65,205
    You jumper the resistor/light bulb across the two wires in the strut/shock suspension control cable.
    Just like bending a paper clip into a U and sticking it into the wall socket. The strut/shock is no longer wired to the car so you install resistors in the cable ends to "fool" the car's suspension control systems.
    |_____wire 1______resistor_____wire 2____|
    Threads have been merged - let's keep it all in one place.
  15. #14
    Feb 2019
    28
    correct this is what i have done
  16. #15
    Feb 2019
    28
    Any update would be great, keep in mind I'm using (2ohm 10watt) on all 4 stuts connected into the top
    Still getting two warning " suspension service and 80mph limit"
Similar Threads
  1. Active to passive strut resistors.
    By Caddy-EaRL in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 08-11-18, 07:55 PM
  2. Does anyone have a picture of the resistors that are need to remove suspension light
    By mauricepalmer9494 in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 04-23-14, 10:18 PM
  3. 2009 front MRC to passive possible?
    By 2muchspl in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 02-20-14, 08:14 PM
  4. Any way to bypass air suspension without going to Arnott? Building resistors DIYs?
    By 07maralade in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 11-04-11, 10:44 PM
  5. Service suspension system resistors
    By Mopar500 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 11-06-10, 01:26 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
