2014 SRX runs very hot at idle
Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By DavidH62
  • 2 Post By guy2545
  • 1 Post By KRDCAD
Cadillac SRX Second Generation Forum (2010-2016) Discussion, 2014 SRX runs very hot at idle in Cadillac SRX; Been doing this lately, temp gauge just about peaks at idle, AC stops working. Happened about a year ago and ...
    Olustee bus is offline Cadillac Owners Member
    Automobile(s): srx
    Feb 2012
    29
    Been doing this lately, temp gauge just about peaks at idle, AC stops working. Happened about a year ago and now it is happening more often. Turn the AC off and lower windows and it cools off to a safer temperature. No message shows up. Anyone else have a similar problem
    Thanks
    Buster
    DavidH62 is online now Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Lux
    Dec 2015
    Minneapolis
    143
    Re: 2014 SRX runs very hot at idle
    Are the engine cooling fans working when the engine is hot?
    Coolant level good?
    And does the warning light come on when the gauge reads hot?
    Olustee bus likes this.
    Automobile(s): srx
    Feb 2012
    29
    Quote Originally Posted by DavidH62 View Post
    Coolant level good?
    When I turn the engine off, the cooling fan continues so I assume they are working.
    coolant level is ok.
    good question. No, I have not seen the warning light.
    Thanks for responding.
  5. #4
    Dec 2015
    Minneapolis
    143
    I'm not sure of your conditions but a number of situations may cause the engine to run hot such as extended periods of stop and go traffic. This may be normal.
    If your temp warning light has not illuminated then you likely have not exceeded max allowable temperatures.
    If your AC quits working by itself at any time I would have that checked out.
  6. #5
    guy2545 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac SRX Performance / 2009 Escalade Hybrid
    May 2015
    Texas
    14
    The connector for my engine cooling fans had melted a little due to the current from the speed resistors. It would sometimes stop working and the engine would over heat. I bought a new connector for the engine bay wiring harness and that fixed the problem for me.
    Olustee bus and DavidH62 like this.
  7. #6
    KRDCAD's Avatar
    KRDCAD is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 SRX LUX 2014 CTS LUX Phantom Grey (previously 2008 STS)
    Jun 2016
    Tidewater Virginia
    76
    1,482
    I'm sure it didn't fix the head gasket issues you are likely to have from the engine overheating.
    WILLY92 likes this.
Similar Threads
  1. Hot air, and a VERY hot CLU
    By Swaman in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 04-14-15, 09:33 PM
  2. 2014 Cadillac CTS 3.6 vs. 2014 Audi A6 3.0T, 2014 BMW 535i xDrive, 2014 Mercedes-Benz
    By ep_83 in forum 2014+ Cadillac CTS General Discussion
    Last Post: 12-06-13, 09:33 PM
  3. '92 Deville 4.9 runs great at startup, runs like crap when hot
    By Bluenose1 in forum HT4100 4.1, 4.5, 4.9
    Last Post: 09-22-07, 10:58 PM
  4. 4.1 Alternator Very Very Hot.
    By thesaintnr1 in forum Electrical Technical Information
    Last Post: 07-28-05, 11:32 AM
  5. '95 SLS Runs hot, then not, now hot again
    By sandyrdsp in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 09-01-04, 09:43 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
