water leaking from the vent on the bottom floor pan
Results 1 to 3 of 3
Cadillac SRX Second Generation Forum (2010-2016) Discussion, water leaking from the vent on the bottom floor pan in Cadillac SRX; I just noticed water dripping from the bottom of my 2014 SRX. It only has 44K miles. It looks like ...
    banph's Avatar
    banph is offline Cadillac Owners Member
    Automobile(s): 2014 SRX, 2012 CTS-V Sedan 6spd, 2017 Z06
    Apr 2009
    Auburn, NH
    40
    I just noticed water dripping from the bottom of my 2014 SRX. It only has 44K miles. It looks like its coming from the drain hole on the bottom of the middle floor pan. I assume this is where the condensation drips from when the air condition is on, however I have not used the Air and it seems to be dripping all the time. Just noticed this today. It clearly is water. Any one out there have an idea why? Its been very rainy here in NH lately but the car is always garaged. Typically when the drip occurs from when the air is on in the summer time, the condensation goes away quickly after the engine is turned off, however its been 3 hours and the water is still dripping.
    any help would be appreciated.
    Thanks
    adamjeeps is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 SRX Performance FWD
    Oct 2007
    1,599
    Re: water leaking from the vent on the bottom floor pan
    The a/c runs sometimes even when you don't specifically tell it to. Make sure it is completely off.
    Check you sunroof drains on each corner by pouring water down each one. The water should drain fairly quickly. If not, you may have a drain partially clogged or loose from the fitting. Check your floors for damp carpet all over, including under the rear hatch where the spare tire kit is.
    banph's Avatar
    Apr 2009
    Auburn, NH
    40
    Thanks, I will check the spare tire compartment as well.
    No water on the floors. I think it was humid day and we had the air on by mistake. That is all i can think might of happened. Not leaking now.
Similar Threads
  1. Weird AC vent problem - Rear vent/floor coming out backwards?
    By juissed in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 08-12-15, 04:02 PM
  2. water leaking from hole on bottom of water pump.
    By turbol15 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 08-19-12, 10:20 PM
  3. Woke up to find water in left rear floor pan?
    By tx.cts in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 12-01-08, 01:29 AM
  4. Rear Passenger floor pan water leak
    By Golfer in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 09-27-07, 04:20 PM
  5. Water coming out of bottom heat vent
    By weister42 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 10-19-06, 05:06 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
