2004 SRX 3.6l cranks, but won't start
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2004 SRX 3.6l cranks, but won't start in Cadillac SRX; I have an old SRX that has served me well with 230k miles on it. About a month ago, the ...
    areyouwireless is offline Cadillac Owners Member
    Jul 2011
    1
    I have an old SRX that has served me well with 230k miles on it. About a month ago, the car was running fine and my wife parked it in the driveway. Next day I went out to start it and it won't start. Battery is fine, gas feed is fine (checked with a fuel pressure gauge). When cranking the engine, it sounds like it wants to start, but just won't fire. It's been a while since I last changed the plugs (over 100k miles), and I happen to have new coil packs on hand, so I replaced all the spark plugs, coil packs, and for good measure, the fuel injectors. No luck. I then figure it might be the cam shaft positioning sensors, so I changed them also. It is throwing no codes, and no old codes are recorded. I searched the forum, but couldn't find anything specific that I haven't tried already. Anyone have thoughts on how to go about diagnosing the problem?
    G1 SRX's Avatar
    G1 SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX N* AWD
    Aug 2016
    Canada
    574
    Re: 2004 SRX 3.6l cranks, but won't start
    Sounds like a fuel or firing issue, but since you've checked that, I'd try a new battery...many a story on here about thinking the battery was good, even tested good, but was not good enough for starting. Also some have had a battery cable internally broke and/or poor connection either at battery or at ground.
    No timing chain issues?
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,133
    Did you check to see if the air intake valve is maybe stuck or carboned up? I have seen issue with hard starting due to that, especially in colder weather. Just a thought...
Similar Threads
  1. CTS 2005 3.6L AUTO cranks but no start
    By yesyesyesyes1111 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 03-13-18, 12:22 PM
  2. '06 SRX cranks, but won't start. Help me diagnose?
    By e2mtt in forum Cadillac SRX First Generation Forum - 2004 - 2009
    Last Post: 06-24-13, 03:52 PM
  3. 2005 CTS 3.6L Cranks But Will Not Start
    By rodneyk915 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-08-13, 07:15 PM
  4. cranks but won't start
    By festiva1 in forum Cadillac Catera and Cimarron Forum
    Last Post: 07-12-07, 09:03 PM
  5. Cranks, but won't start
    By Luey357 in forum Northstar Engines and System Technical Discussion
    Last Post: 04-15-06, 01:25 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
