CLUNKY transmission
Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By n7don_srx
  • 1 Post By Alucard
  • 1 Post By 08SRX
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, CLUNKY transmission in Cadillac SRX; 05 srx 3.6l rear wheel drive w/115,000miles trans clunks between aprox 45 and 65mph.i live in a mountainous area and ...
    dougman692000 is offline Cadillac Owners Member
    Automobile(s): None
    Jan 2019
    None
    10
    CLUNKY transmission
    05 srx 3.6l rear wheel drive w/115,000miles trans clunks between aprox 45 and 65mph.i live in a mountainous area and whenever trans should downshift it "clunks"and then shifts .i usually dshift manually then back to drive.i am about to service the trans.(filter and fluid}. hoping that will help.
    any ideas...should i use an additive,lucas etc... theres no dipstick on this model so i cant even check the fluid. the computer says 12% trans fluid life left so its way over due. any tips or ideas would be appreciated.
    thanks
    nascarnation is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    70
    627
    Re: CLUNKY transmission
    I'd recommend a fluid & filter change (pulling the pan).
    The only additive I've found that works (and primarily for torque converter chuggle) is lubegard red, so buy a tube and put it in.
    https://www.amazon.com/Lubegard-6090.../dp/B0007ZAJRM
    Valvoline is a good fluid at a reasonable price (can get at Walmart also)
    https://www.amazon.com/Valvoline-Syn...omotive&sr=1-1
    Be careful and don't burn your forearm on the hot exhaust when setting the fluid level....I've got that scar from years ago....
    n7don_srx is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac '07 SRX-V6 RWD, '03 Envoy, '95 S10 pu
    Jan 2007
    Gold Canyon & Happy Jack, AZ
    899
    I've used Amalie Dexron VI in a couple vehicles with no issues. In both cases I used all 12 qts. The pan was dropped, a new filter install and I cut the line going to the transmission cooler so I could add fresh fluid as the old fluid was pumped out. A little more complex than just dropping the pan but doing a flush replaces most of the fluid.
    I second the comment on the nearness of the fill plug to the exhaust. A challenge not to burn your arm/hand
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    G1 SRX likes this.
  5. #4
    Alucard's Avatar
    Alucard is offline Cadillac Owners Fanatic
    Automobile(s): EU - SRX 2004 N* (with autogaz system) AWD, 7seat, trailer hitch westfalia.
    May 2017
    France, Charente.
    37
    144
    Normaly the gearbox is the same type of my 04 N*.
    I use Dexron VI, i just change oil not the filter 1 week ago (DIC say 45%, european use is severe service).
    5 liters just for the pan, double flushing = 10 liters.
    For fill speeder, i have used an old stainless steel can for wood glue gun (and air compressor for push the fluid) :
    For the fluid level, it is by overflow with the fill plug when oil is between 30°c and 50°c, engine running :
    Always check if the fill plug can open, before open the drain plug !
    Ac delco filter kit (96042545) have the 2 new plug with the filter.
    G1 SRX likes this.
  6. #5
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,132
    This may sound odd, but I had a similar clunk on downshift from 3 to 2 only. Transmission flush barely did anything. Then one of my downstream O2 sensors went out of spec. Since I replaced it, the engine is happier and the rough downshifts are gone. Replacing the bad O2 sensor also returned the original mileage, which I slowly lost and couldn't figure out why. I guess the reason is the engine makes up for wrong sensor readings up to the point, where it can no longer do this and then finally throws a check engine light. It literally takes months before the ECU can no longer make the adjustments.
    G1 SRX likes this.
  7. #6
    G1 SRX's Avatar
    G1 SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX N* AWD
    Aug 2016
    Canada
    574
    Quote Originally Posted by 08SRX View Post
    I wonder if the PO420 cat below efficiency and/or a PO455 Evap large leak would do the same thing?
Similar Threads
  1. clunky shifts-'04 V8 RWD
    By peebles in forum Cadillac SRX First Generation Forum - 2004 - 2009
    Last Post: 05-15-19, 01:59 PM
  2. Transmission clunky and jerky shifts but fine after batter unplugged
    By apollo18 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 03-10-17, 02:39 PM
  3. 2.0 Manual Transmission Kinda Clunky?
    By Rin in forum Cadillac ATS General Discussion Forum
    Last Post: 05-29-13, 03:46 PM
  4. question regarding clunky noise...
    By jaugustavo in forum Suspension, Brakes and Tires
    Last Post: 01-03-06, 04:33 AM
  5. Clunky shifting 6 speed?
    By paulfl05 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 12-13-05, 03:55 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
