Foggy headlight fix
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By 08SRX
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Foggy headlight fix in Cadillac SRX; The headlights on my SRX were looking cloudy and foggy and did not look good. I tried all the remedies ...
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,132
    Foggy headlight fix
    The headlights on my SRX were looking cloudy and foggy and did not look good. I tried all the remedies posted online (scrub with toothpaste, spray WD40 etc) and found that none of those worked. The following made them look crystal clear again:
    1. Sand the headlamp unit with 400 or 800 grit sandpaper using medium pressure. This will make them more cloudy. The goal is to remove much of the old clear coat that has now deteriorated. Allow 5 minutes per side.
    2. Sand with 2000 grit sandpaper. Cloudiness will still persist. Allow 10 minutes per side.
    3. Wet sand with 2000 grit sandpaper until all the white milky substance (old clear coat) is gone. Use PLENTY of water.
    4. Wet polish with 3000 grit sandpaper to remove as much cloudiness as possible.
    5. Remove any loose material, then clean thoroughly with rubbing alcohol to prepare for clear coat spray.
    6. Mask off the corner with a garbage bag and cut a hole for the headlamp lens to expose it. Use masking tape all around.
    7. Apply two very light coats of clear coat from a rattle can. Let dry for an hour.
    8. Apply third medium coat of clear coat.
    9. Let dry for a few hours then remove the masking tape and garbage bags.
    Hope this helps someone.
    G1 SRX likes this.
    G1 SRX's Avatar
    G1 SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX N* AWD
    Aug 2016
    Canada
    574
    Re: Foggy headlight fix
    Nice. I would add to use a UV protectant polish such as Mother's synthetic wax. I use that and find it works well on the whole car, headlights, tail lights etc.
    nascarnation is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    70
    627
    Good work.
    If you have an orbital buffer you can use the various grades of paint finishing polish.
  5. #4
    rdgfx32003 is offline Cadillac Owners Member
    Automobile(s): 2006 SRX 3.6 RWD
    Jun 2018
    Rowlett, Texas
    3
    Using a plastic polish like that found in the 3M headlight restoration kit used with a drill really brings the "NEW" out after the sanding is done. In fact, just go buy the 3M headlight restoration kit. It has everything you need to restore the headlights to like new condition, except there isn't any UV protection included. I don't work for 3M nor am I a shareholder. This is just my opinion as a consumer of such products.
    https://www.amazon.com/3M-39008-Head...gateway&sr=8-3
  6. #5
    Alucard's Avatar
    Alucard is offline Cadillac Owners Fanatic
    Automobile(s): EU - SRX 2004 N* (with autogaz system) AWD, 7seat, trailer hitch westfalia.
    May 2017
    France, Charente.
    37
    145
    Quote Originally Posted by rdgfx32003 View Post
    For have use 3 times this kit, i prefer the Philips Headlight Restoration Kit with UV protection, 1 year without problem like all other kit.
Similar Threads
  1. Foggy Headlamps on your 02-06 Lade? Free fix
    By Stoneage_Caddy in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 02-10-13, 04:25 PM
  2. Foggy headlight
    By Merseyman in forum 2008-2013 Cadillac CTS General Discussion
    Last Post: 06-01-11, 05:47 PM
  3. Headlight Lenses Foggy
    By orange110 in forum Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels
    Last Post: 07-27-09, 12:05 PM
  4. Additional tips for foggy headlamp fix
    By BDuncan in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 11-20-07, 01:40 PM
  5. Foggy Headlight?????
    By PEETYZ in forum Cadillac Catera and Cimarron Forum
    Last Post: 02-14-07, 04:32 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
