06 Trailing Arm: RUSTS itself OUT OF EXISTENCE.
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By G1 SRX
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 06 Trailing Arm: RUSTS itself OUT OF EXISTENCE. in Cadillac SRX; Put the car in reverse yesterday to back out of the driveway... clunk. Then scraping sound. Behold - 12 year ...
    frogblender is offline Cadillac Owners Member
    Automobile(s): 2006 SRX V6
    Dec 2007
    33
    Behold - 12 year old GM product turning into powder: This is what remains of the left rear trailing arm of my 2006 srx.
    - do all 06's look this sh1tty, or is it just me?
    - anyone replace their trailing arms for the same reason?
    BEARBAIT1973 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8 AWD
    Nov 2013
    New Lenox,IL.,Eagle River,AK
    70
    192
    Re: 06 Trailing Arm: RUSTS itself OUT OF EXISTENCE.
    This is the reason I got rid of my 04 a couple years ago. Loved that vehicle but it scared me everytime I looked under it!!!
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,905
    Common in snow/rust belt areas.
    Here's a slightly older Seville up on the rack for exhaust replacement - note the rust on the arms and suspension cradle (Deville is worse, much worse - some horror stories similar to yours in those forums).
  5. #4
    G1 SRX's Avatar
    G1 SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX N* AWD
    Aug 2016
    Canada
    574
    Mine is an '04 in the salt belt. Nothing as bad as yours just some surface rust. I did have a hole in the front rail - nothing serious but I had new metal welded in and the undercarriage sprayed with rust converting paint. The car sub shows looks like simple surface rust not bad at all, but yours is really bad...sorry for that to happen. I get undercarriage washes a number of times in winter and about every two weeks spring to beginning of winter.
  6. #5
    Promodmerc's Avatar
    Promodmerc is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS4 V6
    May 2017
    Raytown MO
    52
    402
    Quote Originally Posted by G1 SRX View Post
    My 2006 STS has the same frame rail rust as you. I need to have a piece welded in as well.
    The rest of the undercarriage isn't bad.
  7. #6
    nascarnation is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    70
    627
    Well the good news is it didn't happen when you were horsing it at 50mph on a 25mph freeway ramp.
    The factory paint on those parts (from a supplier I assume) is pretty inconsistent and you for sure got one that was thin/missed. Now I'm gonna go out and look at the ones on my 99 GMC.
  8. #7
    G1 SRX's Avatar
    Aug 2016
    Canada
    574
    Quote Originally Posted by Promodmerc View Post
    I'm told they rust there because of a resin fill which is supposed to make the frame stronger ...how rusting makes it stronger is something I can't figure out, lol.
    Promodmerc likes this.
  9. #8
    Dec 2007
    33
    They rust cuz they're made from the sh1ttiest cheapest mild steel known to mankind.
    Now might be a good time to point out that Tesla's suspension is aluminum.
  10. #9
    Dec 2007
    33
    In your before pictures, you have some flaky surface rust. Did all that get scrapped off before painting? And you said "rust converting paint" - is there some magical unicorn rust paint I am not aware of?
  11. #10
    G1 SRX's Avatar
    Aug 2016
    Canada
    574
    Quote Originally Posted by frogblender View Post
    There was no flaking rust except for the part of the frame where the hole was. No sanding/scraping. Guess you'll have to find your own magical unicorn.
  12. #11
    Feb 2006
    79
    64,905
    Yes, the underbodies, suspension parts, and frames are stamped from the cheapest, worst kind of "steel" on the planet - usually with NO paint or primer job applied.
    There are several "rust converter" coatings that contain resins and tannins. They stop the rust process and coat/impregnate the rusted areas with a hard waxy brown material. They DO NOT restore any lost steel strength or integrity.
    https://www.google.com/search?q=rust...hrome&ie=UTF-8
    If you buy a car in the rust belt then there's still some small incentive for a Ziebart job - while the car is new.
    https://www.google.com/search?q=zieb...hrome&ie=UTF-8
  13. #12
    Aug 2008
    Indianapolis
    70
    627
    I assume you're joking here, if not search on "whompy wheels"
    Teslas have widespread suspension failures, far more per capita than any other vehicle on the road.
    https://www.flickr.com/photos/136377...7658490111523/
  14. #13
    G1 SRX's Avatar
    Aug 2016
    Canada
    574
    Quote Originally Posted by Submariner409 View Post
    I guess frame rail rust is endemic then. Googling frame rail rust comes up with bad frame rail rust on models of Toyota such as the Tacoma, along with many other brands such as Mitsubishi, Mazda, Miata, Nissan, Chrysler, Jeep, Ford, and the list goes on.
  15. #14
    Feb 2006
    79
    64,905
    Back in the late 50s, when "Nissan" was "Datsun", you could guarantee that it would start to rust out - rust OUT - in less than 12 months.
    I was a part-time engine mechanic at McLean Motors in Georgetown, DC back then - the first Datsun dealer in the middle east coast. Hillman, MG, Jaguar, Austin Healey, Morgan, others. Fun times. Before USN ........
    Look up mid-60s GM mid-size car rust under the rear window corners - guaranteed automatic drains into the trunk.
Similar Threads
  1. How to bypass the metal coolant pipe when it rusts out on a 98 DeVille
    By Slipgate in forum Cadillac Tech Tips - How to fix it
    Last Post: 06-01-17, 09:37 PM
  2. ANOTHER Broken Trailing Arm!
    By mrocha in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 12-11-08, 03:29 PM
  3. Trailing Arm Wanted! Anyone Have One?
    Last Post: 11-28-08, 03:44 PM
  4. Broken Trailing Arm
    Last Post: 04-30-08, 12:24 PM
  5. Engine oil life reset itself (by itself)
    By GOTTSPD in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 11-10-05, 11:06 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
