Rust Spot in Wheelwell of 2009 SRX: What to Do?
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rust Spot in Wheelwell of 2009 SRX: What to Do? in Cadillac SRX; My 2009 SRX V8 has a rust issue in the driver's side rear wheelwell (see image). Otherwise the body is ...
    Alert is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS V8, 2009 SRX 4WD V8
    Aug 2007
    Long Island, NY
    59
    111
    My 2009 SRX V8 has a rust issue in the driver's side rear wheelwell (see image). Otherwise the body is perfect.
    Any recommendations?
    G1 SRX's Avatar
    G1 SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX N* AWD
    Aug 2016
    Canada
    574
    Re: Rust Spot in Wheelwell of 2009 SRX: What to Do?
    Get it cut out and new metal welded in followed by rust inhibitor primer followed body work and painting. After that use RustCure 3000 in all the body panels. If you don't want to go that route you could cover it up with a chrome wheel molding you can find on line for the first generation SRX, but I'd still use the RustCure.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,905
    Yep ^^^^ Very typical of cars in the snow/road chemical belt.
    Once that cancer gets away from you it's a quick downhill process. That looks like it's between two pinch-welded stampings - the worst place for rust to start. Check each fenderwell - I'll bet there's more.
    Repairs for this type of rust are NOT cheap and correct action is very necessary. Yesterday.
    You're not alone - find some pictures of the underside (rear suspension cradle) of a Northstar FWD Deville from the snow belt. Here's another member's Seville during an exhaust install in upstate NY - not good.
  5. #4
    Aug 2007
    Long Island, NY
    59
    111
    I spoke to a local body shop this morning. He says he'll cut it out and replace the area. He'll have to repaint the door right next to it, also.
    $700 -$800.
  6. #5
    nascarnation is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    70
    627
    It's really economics.
    If you feel the car has substantial miles left, and you like the car, go for it.
    If it was mine, I'd be more tempted to go the bondo and spray can route.
    I'd take a look at your brake lines too, that's another area of corrosion concern on these.
  7. #6
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,133
    Also make sure the area does not trap dirt or at least clean it. Metal folds and junctions can collect leaves, dirt and debris. When that happens it traps any moisture and eventually it will start to rust the panels.
  8. #7
    G1 SRX's Avatar
    Aug 2016
    Canada
    574
    Quote Originally Posted by 08SRX View Post
    I have to get a small area above my drivers rear wheel well done. I'll be using RustCure 3000 there and in all other panels to prevent that from happening, plus keeping an eye out for rock chips and repairing them ASAP.
Similar Threads
  1. Rust Spot
    By smittomatic in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 05-25-17, 09:41 PM
  2. Noise coming from the passenger side wheelwell
    By misdeal in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 07-20-14, 02:37 PM
  3. Rust on 2008 CTSDI rear wheelwell
    By swb7 in forum 2008-2013 Cadillac CTS General Discussion
    Last Post: 10-25-13, 02:32 PM
  4. Rust spot on a rear rotor
    By weister42 in forum Suspension, Brakes and Tires
    Last Post: 06-05-07, 09:11 AM
  5. wheelwell Fender shield needed
    By NoCadiYet in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 09-12-06, 07:02 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
