78 Eldo power steering pump bolt - how to loosen
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 78 Eldo power steering pump bolt - how to loosen in Past Cadillac Vehicle Discussion; I want to change my thermostat gasket - it leaks. I read the FSM, foundd out that the AC compressor ...
    87allante is offline Cadillac Owners Member
    Automobile(s): 2001 Eldo ETC, 1987 Allante, 2006 STS previous 66 Coupe, 85 Eldo Biaritz, 75 Eldorado
    Oct 2017
    12118
    69
    66
    I want to change my thermostat gasket - it leaks. I read the FSM, foundd out that the AC compressor needs to be dismounted - friggin' engineers - thought that stuff didn't start till the mid 80s.
    Anyway to move the compressor it appears I have to remove the belt. To remove the belt I need to loosen the 2 bolts holding the power steering pump in place. The outer one (closest to the fender) was no problem. The inner one sits behind the pulley with maybe an inch and a half of clearance - so no socket.
    I found a long 9/16ths open end wrench, put it on the bolt. Bolt is really in there, would not turn. Soaked it with Blaster (waste of time probably, just soaking the head, can't get to the threads).
    Put the wrench on again, really tugged on it, ended up rounding the corners of the bolt head.
    Bought an extra long 9/16ths 12 point box wrench, which does grip the head. Still cannot budge the bolt, even with an extra 6" of leverage provided by a short piece of pipe on the end of the wrench.
    Any ideas? I really do not want to have to take off the pulley, pull the radiator and condenser, and go after the bolt with a long extension and my impact wrench ....
    thanks
    Art
    rodnok01's Avatar
    Feb 2012
    NC
    7,321
    Re: 78 Eldo power steering pump bolt - how to loosen
    A 6 point box end wrench and another box wrench for leverage looped over it(i keep a couple large cheapos just for this). If the bolt snaps it would have anyway using an impact. PB blaster does soak in, also take a punch and rap on heads of bolt maybe it'll loosen it's grip(shock it loose).
    If you can get to the wrench with a hammer consider smaking it also to shock it loose, although it doesn't seem to work as well as the 2 wrenches for me. Good luck.
    cadillac_al2 is offline Cadillac Owners Enthusiast
    Automobile(s): 70 Deville 78 Seville 92 Deville 03 Deville
    Aug 2016
    Maine
    57
    579
    Is that an Olds 350? Most of my Olds engines have a hole in the pulley so you can put a deep socket in there. I seem to remember laying under the car to loosen some bolt when tightening the power steering belt.
  5. #4
    Oct 2017
    12118
    69
    66
    thanks - I will re-soak it, won't be able to work on it till Monday or so, that will give the Blaster a better chance to soak in
    Appreciate the help - I have plenty of 50 cent garage sale vintage wrenches for leverage
    Art
Read about Lincoln | Buick | Genesis | Kia Forte Forum
