2003 SLS window issue (not the motor)
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2003 SLS window issue (not the motor) in Past Cadillac Vehicle Discussion; Hey guys so the other day my Seville’s main window switch got alittle wet when I had my windows down ...
    CorvetteMan115 is offline Cadillac Owners Member
    Automobile(s): 2010 CTS, 2003 CTS (sold), 2000 Deville
    Feb 2016
    lower NJ
    32
    90
    Hey guys so the other day my Seville’s main window switch got alittle wet when I had my windows down and it started to rain, put the windows up and thought nothing of it. The next day everything was fine, then yesterday all the sudden my drivers control will not put the rear driver side window down. The window works fine from the door itself, and my drivers switch will put it up fine but not down. Should I pull the main switch and maybe disconnect it and reconnect it to see or if anything do I most likely need a new master switch?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,213
    Re: 2003 SLS window issue (not the motor)
    You're not the first with wet switch panels and iffy window operation. Luck of the draw: It will dry itself out and work correctly, you might need to remove and clean the switches with electronics spray, or worst case; new switch panel.
    Start off with 5 minutes of warm setting hair dryer blower work.
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,439
    Quote Originally Posted by CorvetteMan115 View Post
    STEP #1 - ALWAYS - check for DTC's - Diagnostic Trouble Codes -
    the switch doesn't activate the windows - that would be WAY TOO EASY -
    remember - this is a Cadillac
    the switch signals the DDM - Driver Door Module -
    the DDM activates the window motors -
  5. #4
    Feb 2016
    lower NJ
    32
    90
    Still not working from the drivers switch.. all windows operate normally expect rear driver side.. and it still goes up but does not go down
  6. #5
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    2,316
    Same symptoms from your first post.
    What have you done since then to troubleshoot the issue?
    If the switch is bad or the contacts fouled, the problem likely won't go away with the passage of time.
    CCC
Read about Lincoln | Buick | Genesis | Kia Forte Forum
