2002 Seville Injector oring
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 Seville Injector oring in Past Cadillac Vehicle Discussion; Replaced the plenum, may have screwed up one of the injector upper orings. A couple of injectors came out of ...
    sefiro's Avatar
    sefiro is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Fleetwood 2dr cpe - FWD, 96 Seville SLS, 02 Seville
    Jan 2007
    603
    A couple of injectors came out of the rail during disassembly, thought I had gotten em back together but clearly leaking fuel on one. Will disassemble again, but might have to relieve the one oring. Any one have spec on it? Initial search only turns up a full package at 35+. I figure these have to come in some std sizes for a buck (instead of waiting a few days for the package).
    Upper. Viton? Other?
    sefiro's Avatar
    Jan 2007
    603
    Re: 2002 Seville Injector oring
    Update, took 3 trys and finally set. Will order up a full set as backup for the next time in.
    71
    85,816
    Be sure to use a drop of oil on them before installing them.............if you didn't the first time.
  5. #4
    sefiro's Avatar
    Jan 2007
    603
    I did. They must be getting old and dry.
Read about Lincoln | Buick | Genesis | Kia Forte Forum
