2002 STS Active Strut Bypass
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 STS Active Strut Bypass in Past Cadillac Vehicle Discussion; I recently changed JUST the front struts on my 02 STS and did not realize the front struts had a ...
    jasonread3 is offline Cadillac Owners Member
    Automobile(s): 2002 seville STS
    Nov 2013
    18
    I recently changed JUST the front struts on my 02 STS and did not realize the front struts had a plug in for electonic monitoring. The new struts I installed do not have the plug in like the originals. I am getting the pesky "speed limited to 90" message. I have seen other posts talking about tricking the computer/sensors. Can I do this while running the new struts I have up front and the oem rear suspension? Any help is much appreciated.
    71
    85,816
    Re: 2002 STS seville
    Not sure if you can do the bypass to half the system or not. Bass may know.
    P.S.
    I edited your title to be a bit more descriptive.
    Nov 2013
    18
    Thank you sir!
  5. #4
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,209
    Re: 2002 STS Active Strut Bypass
    What is the build date of your 2002 - driver's door sticker.
    Before mid-January 2002 the system was the F45 CVRSS active type; after 01-15-02 it changed - ALL STS - to the new F55 MRC active type. (See my username banner)
    Two VERY, Very, VERY different suspension systems, each with their own workarounds when you cheap out and go passive.
    The trick is to insert a resistor in series with the old chassis wiring harness connector, but the type of system determines the value of the resistors used - and they're quite different, too.
    Best to go passive on all 4 corners - a half-active suspension system would be half-assed in performance........ You MUST retain the rear ELC system.
  6. #5
    Nov 2013
    18
    Thanks for the info! Would it be better to just buy the proper front struts? If so, what do those usually run in price? If I am hearing you correct, I need to make the system passive at all 4 corners with the setup I have now. I will check the build date you called out when I get home for sure and report back.
  7. #6
    Feb 2006
    79
    65,209
    If you can find the correct active struts and shocks for your car - and - again - the build date makes a BIG difference - you will pay from $2200 to over $3000 to replace all 4 corners, not including any maintenance for the rear shock ELC system.
    Your entire vehicle stability system is also now dysfunctional - many sensors normally supply body attitude info to the BCM and PCM in order to control the active suspension during all modes of driving - stopped, slow, fast, aggressive. With substitute passive struts/shocks the system is dead.
    ELC = Electronic Level Control - a control system which uses height sensors, a compressor, air lines, and shock bladders to adjust rear ride height in response to added weight in the trunk or rear seat. It is NOT "air ride".
    https://www.cadillacforums.com/forum...-acronyms.html
    Note the two different suspension strut prices - learn your particular system intimately - continue to the shock pricing (hold your heart) -
    https://www.rockauto.com/en/catalog/...ion,strut,7584
  8. #7
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,436
    I recently changed JUST the front struts on my 02 STS.................................
    the best answer is MAYBE -
    while not ideal - you CAN mix active and passive in the F45 system -
    I would NOT RECOMMEND this in the F55 system -
    STEP #1 - determine which system you have - F45 or F55 -
    the resistors used to trick the computer are quite different between the two systems -
    in either case - you have already replaced the struts - (just curious - what brand/model struts did you buy?)
    replacing the rear shocks is cheap and easy - why not simply finish the job?
    MONROE MA822 - $57 - for the pair - with free shipping -
    https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
    that depends on how you drive -
    if you like to drive "on the edge" - taking exit ramps at 90mph - YES -
    the electronic struts and shocks make a big difference in handling -
    if you don't "push the car to its limits on every turn" - NO -
    you will never notice the difference - except for a slightly LESS harsh ride -
    F45 struts - IF you can even find them - are around $750+ EACH -
    F55 struts are cheaper and easier to find - around $600 - EACH -
    F45 shocks - IF you can find them - around $600 - EACH -
    F55 shocks - around $400 each
  9. #8
    Nov 2013
    18
    Much appreciated guys on all the info. I really just want to get the suspension to a spot where the vehicle can be sold. It sounds as though maybe it would be best to remove the electronic rear struts and go passive on the rears as well. Once I get home today I will check on the build date and update here. Next question, who wants to buy a 02 sts with 75k miles two owner? Lol Will get build date on here soon. Thanks again everyone!
  10. #9
    Feb 2006
    79
    65,209
    I've owned my 2002.5 since 11/05 - lots of past fun and games - Not in the Cadillac market - new OR old, any model, now or in the future.
    Your STS, with new struts/shocks that match (and if you go passive you need to tell a prospective buyer that the car is no longer a Seville Touring Sedan) might fetch $500 - $1500, with luck. A "2002" STS went out the dealer's door at close to $58,000, all fees included.
  11. #10
    Nov 2013
    18
    Alright, checked out the build date on my 02 sts. It is listed as 06/02. What are my options? Replace the good electronic struts in the rear with passive? Or do you think it is feasible to run a mixed system?
  12. #11
    Nov 2013
    18
    I hear you on that..I bought my o2 sts from the original owner..it has every option, including paint and wheel options...I have the original window sticker..He paid 65k for it..I cant lie, its a hell of a machine...the old man that had it before babied it...so the motor is still strong and pulls like a freight train...I bought it with 46k miles and it has 75k miles now...Other than this current suspension deal, the car is immaculate in and out.....hoping to hear back if my build date is available to run a "mixed" suspension system
  13. #12
    Nov 2013
    18
    Hey Bass, build date is 06/02...so that is the F55 system? In which you stated you would not recommend running a mixed system. Should I buy passive rear struts then?
    You had asked the brand of the fronts I bought, I beleive they were "Gabriel" or something to that affect and I ordered off Rock Auto. I suppose I could order a passive set for the rear, easy install then I would be matching on all 4 corners.
    Then you guys could give me the walkthrough on tricking the system to get the speed limiter turned off.
    I would like to get all the suspension in place, then take it in for an alignment.
  14. #13
    Feb 2006
    79
    65,209
    A build date of 06/02 is the last of the 2002 model year, so the car has the F55 Magnetic Ride Control system, just like the somewhat later Ferrari and Corvette. 2002.5 - 2003 STS was used as the GM prove-mule for the Lord/DELPHI automobile suspension system before it went worldwide.
    Our "model year" ran from about July of 2001 to June of 2002. The 2003 MY began in July of 2002.
    Yes, you need to return it to all-stock MRC or all-passive. I think you should have bought Monroe struts - basscatt will know.
    Look at your RPO sticker under the spare tire cover. That gives the codes of what's built into THAT car - here's mine. Note the FE3 (sport springs) F55 (Magnetic Ride Control). My build date is 02/02 - F55 production began at line startup in 01-15-02 but there are apparently a very few F55 STS that were hand-assembled in late December 2001.
  15. #14
    Nov 2013
    18
    Great info! So I will replace the rear with a passive unit. I see many options on www.rockauto.com what would be my best bet on there for passive rears? Once I have replaced the rears and am then passive at all 4 corners, then will I be able to "trick" the computer? I will check out that sticker today and see what all the codes are, I will snag a pic of it.
  16. #15
    Feb 2006
    79
    65,209
    For the 2002.5 and later F55 system -
    Ohms is the electrical resistance of the piece; Watts is the power handling capability - power resistors in-circuit can get skin-scalding HOT.
    The "trick" is to bypass each strut/shock chassis electrical pigtail with a 2 or 3 Ohm 5 Watt power resistor, either wirewound or metal film. This simulates the electrical load presented to the chassis control and stability systems by the original active suspension parts.
    Just like bending a paper clip into a U and sticking it into a wall socket. Insulate/waterproof well, wire-tie the pigtail out of the way.
    Look at www.partsexpress.com - or eBay.
    https://www.parts-express.com/cat/re...entiometers/75
Read about Lincoln | Buick | Genesis | Kia Forte Forum
