98 sts no start when hot
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By curtc
Cadillac Seville / Cadillac Eldorado Forum Discussion, 98 sts no start when hot in Past Cadillac Vehicle Discussion; After a 30 minute drive or so, I turn it off and will not start again until it cools down. ...
    Tmfusco@me.com is offline Cadillac Owners Member
    May 2019
    4
    No start 98 sts
    After a 30 minute drive or so, I turn it off and will not start again until it cools down. However I tried moving the shifter back and forth and that worked a few times. Any ideas?
    Quick reply to this message Reply
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    33
    6,320
    Re: No start 98 sts
    1st off, you're in the wrong forum, you need to go to the Seville forum, not the STS. Sounds to me that if fiddling with the shifter improves things you have an intermittent failure of the neutral safety switch that gets worse with heat. You'll have better luck in the Seville forum though, heck, a mod might even move this post over there for you eventually.
    nate6966 likes this.
    May 2019
    4
    Re: No start 98 sts
    Thanks for the info and the heads up. I'll go to Seville forum.
    Threads have been merged into Seville. Sub.
  5. #4
    May 2019
    4
    After engine is hot from a drive it will not always restart. A few times I ran the shifter up and back and it starter. Also it will restart when it cools down. Any ideas? Thanks.
  6. #5
    Harry Yarnell is online now Cadillac Owners Connoisseur
    Automobile(s): 2001 eldorado,2008 DTS,2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    75
    1,453
    Re: 98 sts no start when hot
    Do you mean it won't crank, or won't start?
  7. #6
    May 2019
    4
    Will not start
  8. #7
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,201
    Re: No start 98 sts
    So you turn the key to START and it rolls over and over for some period of time but will not catch, run, idle ?
    Or, you turn the key and nothing happens (as in: no crank)?
  9. #8
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    27
    4,110
    Classic leaky FPR symptom I would say, shifter thing was probably just a coincidence. Check for the presence of fuel near the vacuum fitting of the fuel pressure regulator. It should be dry.
Read about Lincoln | Buick | Genesis | Kia Forte Forum
