2002 SLS - install aftermarket stereo - data and security problems
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 SLS - install aftermarket stereo - data and security problems in Past Cadillac Vehicle Discussion; I took the sterio of my 2002 Cadillac Seville, and then air bag , battery and tractions light are on ...
    serioja123 is offline Cadillac Owners Member
    Automobile(s): 2002 SLS
    Apr 2019
    Sacramento
    11
    I took the sterio of my 2002 Cadillac Seville, and then air bag , battery and tractions light are on afte I wire an aftermarket sterio. also the anti theft system is on, how to fix it?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,209
    Re: instal aftermarket sterio
    The original stereo sound system head unit is a necessary part of the car's serial data bus, TheftLock, and security systems.
    You need to reinstall the original wiring and connectors and head unit, get the system working again then talk to the guys at Crutchfield about the correct jumper harnesses and wiring - that retains the old head unit in the trunk to run the rest of the car.
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,436
    Re: 2002 SLS - install aftermarket stereo - data and security problems
    Quote Originally Posted by serioja123 View Post
    there are two special harnesses/adapters that MUST be used for a successful radio swap -
    do the swap without the adapters - the car MIGHT not even start/run again -
    HOPEFULLY you didn't hack up the original harness -
    start over -
    reinstall the original radio - get everything back to "normal" -
    cross your fingers -
    clear all the DTC's that obviously have been set -
    obtain the correct adapters -
    try installing the aftermarket radio -
  5. #4
    Apr 2019
    Sacramento
    11
    The car starts and drive, I did not cut the original harness,. i had a female harness that I conected to the stereo, i hope I conected everything right,
    the only thing now is that when I put the original radio back it does not work, excite the clock buttons.
    also parking break does release anymore , I have to do it manually.
    to clean all the codes could I use a simple obd II?
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    67
    18,436
    our cars have a built-in scanner that will display all stored codes -
    MUCH better than MOST hand-held scanners -
    to check for DTC's - Diagnostic Trouble Codes -
    if you don't know how - go here -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    post any codes you have -
    ALONG WITH THEIR DEFINITIONS -
    include whether they are C-Current or H-History -
    for code definitions - go here -
    http://www.cadillacfaq.com/faq/answers/dtccode.html
    here is a how-to video -
    https://www.youtube.com/watch?v=0PQhWmlbG_A
    after checking/clearing the codes -
    if the radio and other electronic components still don't work -
    check the fuses - BOTH under the hood and under the back seat -
  7. #6
    Apr 2019
    Sacramento
    11
    I foud this harness adapters OS2GM32X and Axxess Technologies GMOS-06 which one will work?
  8. #7
    Apr 2019
    Sacramento
    11
    I put the original back looks like everything went back to normal except the parking break. So what harness adapter should I use for aftermarket radio
  9. #8
    Feb 2006
    79
    65,209
    Post #2.
Similar Threads
  1. Want to install aftermarket stereo in 1997 SLS
    By paulikorg in forum Cadillac Audio, Video and Security Systems
    Last Post: 04-13-15, 03:38 PM
  2. how do I keep my factory security system working with aftermarket stereo?
    By westman995 in forum Cadillac Audio, Video and Security Systems
    Last Post: 01-02-15, 12:52 PM
  3. No Start, no PCM data, and no ABS Data 03 DHS
    By Phantom Zombi3 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 09-22-14, 10:45 PM
  4. NO TCS DATA and NO IRC DATA
    By Cleaner1974 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 03-01-11, 09:48 PM
  5. 90 Deville..Blinking Fuel Data, and Enviro Data Display...Help
    By darrbey in forum Electrical Technical Information
    Last Post: 02-24-04, 03:03 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
