91 Eldo dash lights go out!
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By basscatt
Cadillac Seville / Cadillac Eldorado Forum Discussion, 91 Eldo dash lights go out! in Past Cadillac Vehicle Discussion; My 91 Eldo just had the dash go dark. No lights anywhere. No codes either. It runs and drives OK ...
    bschelle is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1991 Eldorado, 1999 Deville (retired)
    Jan 2004
    Norhtern IL
    362
    My 91 Eldo just had the dash go dark. No lights anywhere. No codes either. It runs and drives OK but the dash going dark is a problem. It did it while I was driving and came back by itself. It did it numerous times but never quit running. I have the battery on a charger to see if maybe it is the problem. Any suggestions?
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,434
    Re: 91 Eldo dash lights go out!
    Quote Originally Posted by bschelle View Post
    could be as simple as a loose/dirty ground -
    Phideaux likes this.
    Jan 2004
    Norhtern IL
    362
    I did have the battery out to fix a hose. I will check the terminals to make sure they are clean and tight. I also have the following codes but doubt if they have anything to do with it.
    E013-right o2 sensor not ready
    E052-ECM memory
    B120-twilight sentinel
    B121-" "
    B448- AC issue (not connected or working)
    B552- battery was disconnected
  5. #4
    sefiro's Avatar
    sefiro is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Fleetwood 2dr cpe - FWD, 96 Seville SLS, 02 Seville
    Jan 2007
    600
    Check grounds, then BCM
  6. #5
    Jan 2004
    Norhtern IL
    362
    I removed and installed the battery cables and all seems right. I drove it about 10 miles and the dash was fine.
  7. #6
    91FleetwoodCoupe's Avatar
    91FleetwoodCoupe is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Fleetwood Coupe (& 1990 Lincoln LSC SE)
    Oct 2016
    29
    353
    Does the headlight switch act as a dimmer knob for this? Could need replacement or simply to be turned.
  8. #7
    Jan 2004
    Norhtern IL
    362
    The dimmer has no affect. When the dash is lit, the dimmer works as usual. I think it was a bad ground from the battery. Time will tell.
  9. #8
    retroren1 is offline Cadillac Owners Fanatic
    Automobile(s): 1988 Eldorado & 1991 Jaguar XJ6 Sovereign
    Jul 2016
    Oakland Co. MI
    131
    I had that problem on my '88 eldo. It was the Central Power Supply. Also, I just experienced this on my '92 Toronado and that time it was the photocell that sit at the base of the windshield in the center. I saw that you have an error code for the twilight sentinel which the aforementioned photocell plays a big role in. Hopefully you fixed your problem.
Similar Threads
  1. 96 Eldo, instruments and lights go out after about an hour running.
    By Jaguarxkr in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 12-15-12, 11:37 PM
  2. Dash lights not working. Window lights, mirror lights, stereo lights all still workin
    By zunie75 in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 11-30-12, 06:26 PM
  3. Climate Control/Fuel Average Lights Go out When Headlights Go On
    By merkley??? in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 01-02-09, 07:55 PM
  4. Go Yanks, er, go Packers, er, go Boilers...how about go Caddy!
    By goebel in forum Community Lounge, Introductions and General Discussion
    Last Post: 10-23-07, 07:44 PM
  5. 98 seville - Dash lights go out
    By Crown Vic Owner in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 09-30-07, 01:22 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
