1996 STS horn question(s)
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1996 STS horn question(s) in Past Cadillac Vehicle Discussion; I have a 1996 Seville STS. Something caused the alarm to activate one night setting of the system. I don't ...
    dv53 is offline Cadillac Owners Member
    Automobile(s): 1996 STS
    Aug 2016
    central Florida
    55
    I have a 1996 Seville STS. Something caused the alarm to activate one night setting of the system. I don't know how long the horn was making noise and flashing lights, but it stopped when I was walking to the car. I opened the hood and a burning smell was emitting by the battery. I found the horn under the right front fender below the battery area, pulled it for a test, and it does not work. Maybe it burned up from running a long time. I've heard these cars have 4 horns, if that's the case, this one was the only one making noise when the alarm was activated.
    If there are 4, are they wired in series where when one goes out you lose them all?
    If no, why was I only hearing one horn if there's 4?
    Curious because I don't have a horn now. Thanks!
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,439
    Re: 1996 Seville STS horn question(s)
    if the alarm is activated -
    the horns will honk and the lights will flash for 5 to 7 minutes - then reset -
    your car two horns - a hi tone and a low tone -
    both activated by a single horn relay -
    simply burned out - they are 23 years old - nothing lasts forever -
    either the remaining horn also burned out -
    or the horn relay failed - located in the MAXI-FUSE box - under the hood -
    Aug 2016
    central Florida
    55
    Thanks. I'll buy a replacement horn, if that doesn't work, I'll switch a good relay in the box out with the horn relay and go from there.
    Do you know where the other horn is?
    Assuming at least one horn is good, will it work if the relay is good?
    Thanks again!
  5. #4
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,213
    Re: 1996 STS horn question(s)
    2 horns (#2) and they should be paired together............
  6. #5
    Aug 2016
    central Florida
    55
    Were there exceptions? I can clearly see one horn and there's not room for another one. If there was room, the bracket holding the one horn would have to share the other horn and I would have another power source hanging in there for the missing one. There isn't a spare hole on the bracket for another horn and there's not another power source coming in for another horn. I can take a picture if you like. Thanks!
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    67
    18,439
    Quote Originally Posted by dv53 View Post
    there were definitely two horns - probably one on each side -
    look up in the fender area - basically behind the headlights -
Similar Threads
  1. Horn issue 1999 DeVille - only one horn sounding
    By chykov in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 07-06-17, 11:28 PM
  2. Horn Cam Replacement - Horn Does Not Work - 1999 Eldorado
    By Skitle47 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 06-26-17, 07:14 PM
  3. I only want horn to sound ONLY when I press the horn button
    By Rapalyea in forum **Cadillac User Experience (CUE)**
    Last Post: 10-07-16, 10:35 AM
  4. 1996 STS Horn Not Working Help Needed
    By Frankma in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 08-23-12, 11:12 PM
  5. Horn on my 2007 cts is very weak, i want to get another horn any ideas what type?
    By Etherington in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 01-15-11, 06:22 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
