1992 Eldorado alarm won't shut off
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By basscatt
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1992 Eldorado alarm won't shut off in Past Cadillac Vehicle Discussion; I recently purchased a 1992 Eldorado which the previous owner had parked for 2 years because the alarm would go ...
    Fiasco is offline Cadillac Owners Member
    May 2019
    I recently purchased a 1992 Eldorado which the previous owner had parked for 2 years because the alarm would go off after starting the car. He unplugged the horns, and just drove it with the lights flashing. After about 3 minutes, the lights would quit flashing. I have pulled every fuse related to security under the hood, including the ones under the large plastic cover. I did the same with the ones in the trunk. Whenever I found one that disarmed it, and pulled it, the starter would not engage. It seems to arm after using the power door locks. I would like to disarm it, or, if not feasible, possibly fix it. I cannot afford to go to the dealer. I do not have a key fob, and only have the chipped key and a trunk key. Thank you in advance.
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,321
    Re: 1992 Eldorado alarm won't shut off
    correct -
    I do not have a key fob -
    THAT might the biggest problem -
    the alarm is automatically armed/disarmed by using the fob -
    you can buy a used fob for as cheap as $6 - with free shipping -
    https://www.ebay.com/itm/OEM-Cadilla...1851#vi-ilComp
    YES - you can match the fob and car yourself -
    OR - try this method -
    this is copied from the 1993 Eldo Owners Manual - the 1992 should be identical -
    the theft deterrent system won’t arm if you lock the doors with a key or manual door lock.
    It arms only if you use a power door lock switch or Keyless Entry System.
    If you don’t want to arm the theft deterrent system,
    the vehicle should be locked with the door key after the doors are closed.
    Phideaux likes this.
    May 2019
    Thanks!
Similar Threads
  1. 94 Eldorado Blower motor won't shut off/run above min speed.
    By jrgongwer in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 09-04-17, 02:32 PM
  2. Hazard lights randomly come on and won't turn off unless car is shut off
    By schmiot in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 07-16-17, 06:13 PM
  3. 2000 Eldorado Blowe won't shut off
    By Stumann in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 02-10-15, 06:25 PM
  4. Alarm won't shut off evern after engine starts
    By 1focus4real in forum Cadillac Audio, Video and Security Systems
    Last Post: 03-09-07, 06:58 PM
  5. 91 eldorado heat won't shut off
    By jandura in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 03-12-04, 10:16 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
