F45 Trick - Resistor Question
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, F45 Trick - Resistor Question in Past Cadillac Vehicle Discussion; 2002 Eldorado ETC VIN9 230K miles with Northstar Performance SureGrip HeadStuds installed at 215,011 - maintenance not blown HG. HI ...
    Eldorado99ETC is online now Cadillac Owners Member
    Automobile(s): 1999 Eldorado Destroyed by Tim Carroll/CCC & 2002 Eldorado Touring Coupe
    Jan 2016
    Rapides Parish, La.
    43
    HI all, unfortunately it's now time to change my front struts. I have a set of Monroe conventional struts arriving at 7am tomorrow (Fri) morning. I should have time to get it to my mechanic when he opens at 8. Hopefully, he will finish in time for me to have it aligned. I want to drive it Sat morning to Texas to attend a cousins wedding.
    I know about the 4.7K OHM 1/2 Watt Resistors that I will need to defeat the Speed Limited to 90MPH Code.
    All the RadioShack stores near me closed years ago. The Resistors are also unavailable online.
    There is a Ralph's Electronics here and just got back from there all they had in stock was 3 - 4.7K OHM 2 Watt Resistors which I purchased. Before I left they checked and another store about 100 miles from here had some, so they ordered some and were supposed to be there in the morning.
    On the way home they called and said that store didn't have any in stock after all. Then the call dropped.
    I haven't called them back yet.
    I guess my question is, will the 2 Watt Resistors work? Are there any other sizes that will work? They also had in stock the 4.7K OHM Resistors but 1/4 Watt. I passed on them thinking they were too small. Will the 1/4 Watt Resistors work?
    Thanks in advance.
    Harry Yarnell is online now Cadillac Owners Connoisseur
    Automobile(s): 2001 eldorado,2008 DTS,2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    75
    1,422
    Re: F45 Trick - Resistor Question
    2 watt ones will work just fine.
    Jan 2016
    Rapides Parish, La.
    43
    Thanks. I do need 4 total Resistors, right? This is what I had understood the number I would need - 2 each Strut. If I just needed two Resistors that would be great.
  5. #4
    Dec 2004
    perryman, MD
    75
    1,422
    One 4.7k resistor per strut.
  6. #5
    basscatt's Avatar
    basscatt is offline Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,279
    Quote Originally Posted by Eldorado99ETC View Post
    Thanks in advance.
    here ya go -
    a 10-pack for $1.69 - with free shipping -
    https://www.ebay.com/itm/1-2W-5-Watt...53.m1438.l2649
  7. #6
    Jan 2016
    Rapides Parish, La.
    43
    Thanks. Order placed. (I probably should have wrote that the Resistors are unavailable from RadioShack online.)
  8. #7
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,837
    One correct value resistor per strut/shock................. 2 resistors paralleled = 1/2 the rated resistance; 2 resistors in series = twice the rated resistance.
    Another place to look is www.partsexpress.com.
    When using resistors the value of resistance is the target; power handling ability - Watts - depends on the electrical load drawn by the affected circuit. Circuits with low current flow - F45 in this case - need only small power rating resistors. Higher current loads - F55 - need larger current handling resistors - 5 or 10 Watt.
    Sort of like electrical wiring and connectors - the larger the load, the larger the wire/connector.
Similar Threads
  1. 'service suspension system' resistor trick - will it work?
    By wangstarr03 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 03-08-18, 01:31 PM
  2. 92 Deville resistor in PCM burned. Does anyone know what this resistor does? See Pic
    By rmbb in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 08-05-15, 02:15 PM
  3. F45 shocks and struts question
    By Caddydrummer67 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 10-07-14, 02:34 AM
  4. resistor trick for service suspension system
    By burns leavitt in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 05-22-14, 04:26 AM
  5. Size of resistor needed to trick electronic suspension.
    By Assassin Tugboat in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 03-15-13, 02:23 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
