Need to change the oil pan gasket on my 99 ETC. How hard is it?
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By rodnok01
Cadillac Seville / Cadillac Eldorado Forum Discussion, Need to change the oil pan gasket on my 99 ETC. How hard is it? in Past Cadillac Vehicle Discussion; Was told it was a difficult repair where the engine had to be almost removed, is this true? Thanks for ...
    92WHTSTS's Avatar
    92WHTSTS is offline Cadillac Owners Fanatic
    Automobile(s): 99 ETC
    Jan 2011
    Farmington Hills Mi
    332
    Was told it was a difficult repair where the engine had to be almost removed, is this true? Thanks for any replies....
    rodnok01's Avatar
    Feb 2012
    NC
    7,274
    Re: Need to change the oil pan gasket on my 99 ETC. How hard is it?
    Cradle has to come down at least IIRC, the pans aren't super bad leakers but the half case is and rear seal, I did Normserts while it was out as my car was leaking badly and half the work was taking engine out.
    Have you checked the OP sender for leaks as they are know issue?
    Unless doing the work yourself or engine is really puking oil not sure I'd fix it(think cost of few qts of oil a year and car wash vs expensive repairs).
    I'd also verify the cam covers weren't the source of the leak(or even just change them) before dropping the cradle and doing pan.
    CaddyDeville00 likes this.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,907
    GM labor time, in a GM shop with all the special tools and new procedures (no gasket - RTV Gray), is 14 hours.
    Yes, it's a damn near total disassembly procedure.
    Not fun - find the weep/leak FIRST.
  5. #4
    92WHTSTS's Avatar
    Jan 2011
    Farmington Hills Mi
    332
    Quote Originally Posted by Submariner409 View Post
    That's crazy !! Why would they design something like that, to make it so hard to replace? I guess to eliminate the "Shade Tree" mechanics, such as myself. I don't even know if I should attempt to replace it. When I had the oil changed, they told me it was leaking. The labor alone will be a killer, for 14 hours, and the gasket cost $20.00. Ridiculous.....
  6. #5
    92WHTSTS's Avatar
    Jan 2011
    Farmington Hills Mi
    332
    Quote Originally Posted by rodnok01 View Post
    What is a OP sender? Oil pan I presume.
  7. #6
    CaddyDeville00's Avatar
    CaddyDeville00 is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Jan 2018
    Wilmington, Ohio
    37
    Quote Originally Posted by 92WHTSTS View Post
    Actually, I believe they’re referring to the Oil Pressure Sender.
  8. #7
    Feb 2006
    79
    64,907
    Oil pressure sender - on the top side of the oil filter adapter.
    No "gasket" (silicone seal) is used for the updated Northstar pan seal replacement - a measured bead of RTV Gray is used in the existing seal groove.
Similar Threads
  1. 92 Deville oil leak between oil pan and trans pan
    By WastedBugsBunny in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 03-01-17, 11:07 PM
  2. new oil pan new oil pan gasket
    By bigvelp07 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 05-14-16, 08:57 PM
  3. Oil Pan Gasket , Head gasket, What to do?
    By sp4149 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 08-10-11, 01:47 PM
  4. Oil pan plug and oil pan
    By SusanT in forum Cadillac Catera and Cimarron Forum
    Last Post: 10-14-08, 05:54 PM
  5. Oil Pan gasket & Trans Gasket 97 Deville
    By dano2407 in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 07-14-08, 04:15 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
