High Revs After Drive
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, High Revs After Drive in Past Cadillac Vehicle Discussion; I'm kind of stumped. My RPMs are going up to 1100-1200 after a drive when I shift in to park. ...
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,311
    I'm kind of stumped. My RPMs are going up to 1100-1200 after a drive when I shift in to park. If I turn the car off and back on, drive around the block, go back in to park it won't happen. Only on legit drives when the car has be going for a few minutes.
    Today a new symptom started. I was going 40-50 and the RPMs just kind of stayed high and I didn't feel the car shift where it normally does. I did the IAC back in December to fix a stalling problem so I know that is good. This new thing today kind of reminds me of what it felt like when the CAT was going bad (but got a new one of those last summer).
    I've got two codes, the old P0410 for secondary air (pump is new and I hear it run from time to time, I think electrical connector may be bad and have a new one to install). Or that pump code could be coming from one of those valves being bad. I'll start with the connector. The newer code is P0442, maybe that is tied to one of those valves being bad? Would the P0442 cause the RPM issue?
    71
    85,739
    Re: High Revs After Drive
    When was the TB last cleaned?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,907
    P 0442 = EVAP system (air) small leak. MAYBE during the drive - but EVAP does not bleed fuel vapor and air air to the throttlebody at less than XX steady mph or before XX minutes at XX steady mph.
    https://obdii.pro/en/model/gm
    As posted, TB cleaning, search for vacuum leaks.
    Your 2002 EVAP and vacuum diagrams .............. click to enlarge, follow the prompts at the lower edge of the picture.
  5. #4
    Sep 2003
    NY
    1,311
    Thanks for the replies guys. The TB is probably pretty clean. I do that stuff pretty regularly. Tonight when I was investigating a new sound from coming out of the driveway (rear stabilizer bar decided to snap), the RPMs were doing the low bounce thing. Its almost as if the new Delphi IAC is already going bad.
Similar Threads
  1. Engine tick at high revs after new cam and lifters
    By biiz1957 in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 12-15-09, 07:59 PM
  2. High revs on start up
    By gbcaddy in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 11-21-09, 03:28 PM
  3. 94 Eldo engine revs high then dies.
    By Petrella in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 08-25-08, 06:21 PM
  4. 96 STS IPC swap problem starting high revs
    By jorghenry in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 11-02-06, 07:43 PM
  5. Cadillac Revs Up...cept they forgot to drive an SRX
    By imthduke in forum Cadillac SRX First Generation Forum - 2004 - 2009
    Last Post: 03-27-06, 08:06 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
