76' Eldorado Climate Control Issues
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 76' Eldorado Climate Control Issues in Past Cadillac Vehicle Discussion; Good Evening Everyone, I am hoping someone can help point me in the right direction. I am working on the ...
    gjmcguinness's Avatar
    gjmcguinness is offline Cadillac Owners Member
    Automobile(s): 1976 Eldorado Convertible
    Mar 2019
    4
    I am hoping someone can help point me in the right direction. I am working on the A/C & Heater and had problems with the programmer, sent it out for repair as it would not actuate at all. Now, as soon as I start the car it goes right to full heat mode. I have tried to search all of the forums, manuals I have etc. to but still cannot figure this out. I know it points to an electrical issue with the 2 temp sensors and the dial but I have checked these individually and they all appear to have resistance so I cannot seem to pinpoint the issue. If you have any ideas, I would really appreciate your help!
    Thanks, Gary
    sefiro's Avatar
    sefiro is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Fleetwood 2dr cpe - FWD, 96 Seville SLS, 02 Seville
    Jan 2007
    574
    Re: 76' Eldorado Climate Control Issues
    Check the temp sensors in both cold and warm air. The resistance should change. Measure then at reinstallation and again through the wire harness back at the controls. (Harness could be adding resistance)
    Mar 2019
    4
    Thanks for the tip! I did check and they do change the ohms based on temperature changes, I also checked the potentiometer on the controls and it appears to work as well. I am really getting stumped on this one.
  5. #4
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 XTS FWD Platinum
    Jan 2003
    Fresno, CA
    939
    Going to full heat means something but I cannot remember what! Before you took the programmer out, did it go to full heat? Did you have the programmer rebuilt? I would bet it's still something with the programmer. There are a few parts in there. Off the top of my head I remember a vacuum check valve. Do you have proper vacuum going to the programmer? Also check the circuitry to make sure all the solders are still attached.
    Max
  6. #5
    Mar 2019
    4
    Thanks Max for your help, I get it figured out last night. I cleaned the contacts on the sensor on the hood and I think the real issue was that it was too cold in the garage and was changing to full heat. I held the in car sensor to make it think it was hotter and everything came back to the A/C modes. I most have read about this but forgot in the all the time I was trying to figure this out. But, Yes, I did have the Programmer rebuilt as well and that's why it has been driving me crazy! Lol
    Gary
Similar Threads
  1. 76 eldorado cruise control issues
    By cadillacindy in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 06-06-16, 09:08 AM
  2. 76 Eldo conv. Climate Control/electrical problem
    By mtravinski in forum The Classic Cadillac Forum
    Last Post: 06-25-14, 06:05 AM
  3. 76 Eldorado Cruise Control Issues
    By bluefleetwood in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 08-20-13, 04:10 AM
  4. 76 Eldo - Climate Control Stuck on Heat
    By awadecki in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 06-15-09, 08:08 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
