View Full Version : Fuel Filter Location Cts 03
savy
05-10-06, 10:53 AM
Any Help Would Be Appreciated...but Does Anyone Know Where The Fuel Filter Is Located In A Cts 03 And How To Replace It? Thanks!!!
BCCADILLAC
05-10-06, 03:10 PM
I hope this helps. You will need special tools for the quick disconnects. this is a good service to let your dealer do.
Chris
Fuel Filter Replacement<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=799184&psdid=230&evc=sm#ss1-799184">
Removal Procedure
Caution: Refer to Gasoline/Gasoline Vapors Caution (http://service.gm.com/servlets/CellHandler?CellId=10119&RefDoc=799184&evc=sm) in Cautions and Notices.
<LI type=1>Keep a shop cloth and a container ready to capture any spilled fuel. <LI type=1>Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure (http://service.gm.com/servlets/CellHandler?CellId=68340&RefDoc=799184&evc=sm) . <LI type=1>Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle (http://service.gm.com/servlets/CellHandler?CellId=47852&RefDoc=799184&evc=sm) in General Information.
http://service.gm.com/engif/000/000/785/785816.gif
http://service.gm.com/tif.gif (http://service.gm.com/servlets/RetrieveTif?pic=785816)
<LI type=1>Disconnect the quick-connect fitting at the fuel filter inlet. Refer to Quick Connect Fitting(s) Service (Metal Collar) (http://service.gm.com/servlets/CellHandler?CellId=68342&RefDoc=799184&evc=sm) . <LI type=1>Using a primary and back-up wrench, remove the threaded fitting at the fuel filter outlet. <LI type=1>Slide the fuel filter rearward from the fuel filter bracket. <LI type=1>Remove the fuel pipe O-ring seal. Discard the O-ring seal if damaged. <LI type=1>Drain any remaining fuel into an approved gasoline container.
Discard the fuel filter into an approved container.<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=799184&psdid=230&evc=sm#ss2-799184">Installation Procedure
<LI type=1>Lubricate the fuel pipe O-ring seal with clean engine oil. <LI type=1>Install the fuel pipe O-ring seal to the fuel pipe. <LI type=1>Remove the protective caps from the new fuel filter.
<LI type=1>Slide the fuel filter forward into the fuel filter bracket. Notice: Refer to Component Fastener Tightening Notice (http://service.gm.com/servlets/CellHandler?CellId=10156&RefDoc=799184&evc=sm) in Cautions and Notices.
<LI type=1>Install the threaded fitting to the fuel filter outlet. Use a back-up wrench in order to prevent the fuel filter from turning.
Tighten
Tighten the fuel filter outlet fitting to 30 N&#183;m (22 lb ft).
<LI type=1>Connect the quick-connect fitting at the fuel filter inlet. Refer to Quick Connect Fitting(s) Service (Metal Collar) (http://service.gm.com/servlets/CellHandler?CellId=68342&RefDoc=799184&evc=sm) .
Lower the vehicle.Fuel Pressure Relief
Tools Required
• J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) Fuel Pressure Gage
• J 42242 (http://service.gm.com/servlets/RetrieveTif?pic=68498) Fuel Pressure Gage Adapter
Caution: Refer to Gasoline/Gasoline Vapors Caution (http://service.gm.com/servlets/CellHandler?CellId=10119&RefDoc=799180&evc=sm) in Cautions and Notices.
Caution: Remove the fuel tank cap and relieve the fuel system pressure before servicing the fuel system in order to reduce the risk of personal injury. After you relieve the fuel system pressure, a small amount of fuel may be released when servicing the fuel lines, the fuel injection pump, or the connections. In order to reduce the risk of personal injury, cover the fuel system components with a shop towel before disconnection. This will catch any fuel that may leak out. Place the towel in an approved container when the disconnection is complete.
<LI type=1>Turn the ignition OFF. <LI type=1>Disconnect the battery negative cable in order to avoid possible fuel discharge if an accidental attempt is made to start the engine. Refer to Battery Negative Cable Disconnect/Connect Procedure (http://service.gm.com/servlets/CellHandler?CellId=37733&RefDoc=799180&evc=sm) in Engine Electrical. <LI type=1>Loosen the fuel filler cap to relieve the fuel tank vapor pressure.
Notice: Clean all of the following areas before performing any disconnections in order to avoid possible contamination in the system:
• The fuel pipe connections
• The hose connections
• The areas surrounding the connections
<LI type=1>Remove the cap on the fuel pressure service connection. Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
http://service.gm.com/engif/000/000/852/852270.gif
http://service.gm.com/tif.gif (http://service.gm.com/servlets/RetrieveTif?pic=852270)
<LI type=1>Connect the J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) (1) and the J 42242 (http://service.gm.com/servlets/RetrieveTif?pic=68498) (2) to the fuel pressure service connection. Wrap a shop towel around the fitting while connecting the gauge to avoid spillage. Caution: Do not drain the fuel into an open container. Never store the fuel in an open container due to the possibility of a fire or an explosion.
<LI type=1>Place the bleed hose of the J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) (1) into an approved gasoline container. <LI type=1>Open the bleed valve on the J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) (1) in order to bleed the fuel system pressure. The fuel connections are now safe for servicing. <LI type=1>Place a shop towel under the fuel pressure service connection to catch any remaining fuel spillage. <LI type=1>Remove both the J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) (1) and the J 42242 (http://service.gm.com/servlets/RetrieveTif?pic=68498) (2) from the fuel pressure service connection. <LI type=1>Drain any fuel remaining in the J 34730-1A (http://service.gm.com/servlets/RetrieveTif?pic=5389) (1) into an approved gasoline container.
Install the cap on the fuel pressure service connection.
ChicagoCTS32
05-10-06, 04:50 PM
Wow... ask and you shall receive! Thanks BC! God bless the service techs we have on the forum...
savy
05-12-06, 02:53 PM
Thanks...a little more than I expected...I probably will have the dealer do it...
savy
05-12-06, 03:07 PM
Do you or anyone else know where exactly (front,rear,left,right) the fuel filter is located the diagram is a little vague...thanks
BCCADILLAC
05-12-06, 03:11 PM
under the car just in front of the right rear tire ( pass side)
