2008 escalade base death wooble
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By lactruck08
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2008 escalade base death wooble in Cadillac Escalade Forums; over small bumps in the the road you can feel the truck wobbles and steering wheel shakes real bad, just ...
    lactruck08 is offline Cadillac Owners Member
    Apr 2019
    1
    over small bumps in the the road you can feel the truck wobbles and steering wheel shakes real bad, just replaced front shocks and balanced wheels, no change, anyone experience this and what else should I check. truck has 156,400 miles.
    pchrist likes this.
    007matman's Avatar
    007matman is online now Cadillac Owners Fanatic
    Jun 2016
    372
    Re: 2008 escalade base death wooble
    First off. You don't have a solid front axle. No way that's Death Wobble.
    Jack up the front end. Grab the tire at 12 and 6 and attempt to move back and forth. Any movement?
    Do the same at 3 and 9. Any movement there?
    Listen for popping sounds.
    Sent from my Pixel 3 XL using Tapatalk
    TecEighty is offline Cadillac Owners Fanatic
    Automobile(s): 2007 ESV
    Aug 2016
    135
    I have similar mileage and felt the same feeling over bumps. I have replaced the shocks, ball joints, upper control arms, swaybar end links, hubs, axles, and wheels and tires. Swaybar frame mounts are solid. Steering rack bushings is my guess.
  5. #4
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    40
    1,221
    I have a 2008 Escalade 2WD and I prefer to drive it over my 2017 Escalade & 2016 Tahoe LT. I replaced both front and rear electric shocks on my 22” stock rims. I went the factory route with the shocks and Bridgestone tires. The newer shocks did say BWI (new part from GM) instead of Delphi/GM goodweench. I do want to say the PSI in the tires need to be at 33-34 psi. I also live in rough-road NYC!
Read about Lincoln | Buick | Genesis | Kia Forte Forum
