2012 phantom electrical issues
Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By Phoenixx
  • 1 Post By Zombo
  • 1 Post By richboy92
  • 1 Post By SpyShops NY
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2012 phantom electrical issues in Cadillac Escalade Forums; Good Evening All, Hopefully you can help. I'm getting some phantom electrical issues. here there are in no order. 1. ...
    torr714's Avatar
    torr714 is offline Cadillac Owners Member
    Automobile(s): 2012 Platinum black ice
    Sep 2011
    New York
    42
    68
    Good Evening All,
    1. when you remote start you hear the stater click once car will not start. if you go in car and turn key starts fine.
    2. once in a blue moon the door locks will cycle and dash cycling.
    3. the other day when the dash and locks cycled after getting were i had to i stop pulled into a parking lot. i shut truck off and the truck acted like it was stone dead battery. can back 20 min later started no problem.
    any help I'm at a loss!
    thank you
    Phoenixx's Avatar
    Phoenixx is offline Cadillac Owners Fanatic
    Automobile(s): 19 Escalade ESV Platinum 08 SRX N* 14 Escalade Platinum
    Jul 2016
    Canada
    462
    Re: 2012 phatom issue
    Quote Originally Posted by torr714 View Post
    Good Evening All,
    thank you
    Could be battery.
    Could be negative and positive cables failure/corroding. Known problem
    torr714 likes this.
    Zombo is offline Cadillac Owners Member
    May 2019
    22
    Re: 2012 phantom electrical issues
    Low voltage does crazy things, +1 on the corrosion
    torr714 likes this.
  5. #4
    torr714's Avatar
    Sep 2011
    New York
    42
    68
    replaced battery three months ago and tested battery showed good. will check cables
    thank you for the input
  6. #5
    richboy92's Avatar
    richboy92 is offline Cadillac Owners Member
    Automobile(s): 2007 Escalade AWD
    Oct 2018
    Wisconsin
    63
    I had similar issues with the door locks and dash but also the throttle.
    I had to replace the ECU to fix the throttle issue, and I haven't had the other electrical issues since.
    I'm guessing they were all related.
    torr714 likes this.
  7. #6
    torr714's Avatar
    Sep 2011
    New York
    42
    68
    Just finished Ohming out the power and ground cable. I found high resistence is the woven cable from the drivers side head to the body. removed it and cleaned it. i haven't had a problem since will keep you all updated
    thanks for all the tips and help
  8. #7
    SpyShops NY's Avatar
    SpyShops NY is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Escalade, 2004 CTS, 2003 ESV, Now 2008 Escalade
    Oct 2012
    Fresh Meadows, NY
    40
    1,221
    There is a 150 amp buss fuse on the firewall or next to the battery. I would start with that if I was you. These trucks are known to have bad battery cables from the factory. You can also use a wire brush to clean all the battery connections as well.
    torr714 likes this.
Read about Lincoln | Buick | Genesis | Kia Forte Forum
