2010 Escalade - Very Rough Bouncy Ride - Solutions?
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2010 Escalade - Very Rough Bouncy Ride - Solutions? in Cadillac Escalade Forums; Hi All - First post here. We have a 2010 Cadillac Escalade as the title states. It seems as though ...
    996
    996 is offline Cadillac Owners Member
    May 2019
    Hi All -
    First post here. We have a 2010 Cadillac Escalade as the title states. It seems as though the suspension has gotten way worse in the last year or two. It is super bumpy and bouncy especially if sitting in the rear, but can be felt all over the car. We went over a bump on the freeway recently and the car felt completely unstable.
    I have read that this may be the magneride suspension going bad... How can I trouble shoot this? If one must replace all 4 magneride shocks, how much will this run me? Can a regular shop do it in stead of the dealer?
    Also is it possible to drop magenride all together and put standard shocks on the car?
    Thanks a bunch in advance. I have heard that his problem is common.
    007matman's Avatar
    007matman is offline Cadillac Owners Fanatic
    Jun 2016
    372
    Re: 2010 Cadillac Escalade - Very Rough Bouncy Ride - Solutions?
    It is pretty common.
    All are options. The OE shocks/Struts are around $250 each on Amazon. If you can do it yourself you'd probably be around $1100 for all four (maybe a little more depending on where you can find it at).
    Replacing with non-magnaride shocks is an option too and quite a bit cheaper. You run the risk of a slightly different ride though with that. You'll need resistors to avoid the "Service Suspension" code.
    I really have good luck with Arnott if you're going the non-magnaride route.
    If you're really noticing it from the rear I might just start with those and see how that improves the ride.
    Someone else may speak up about troubleshooting..
    Sent from my Pixel 3 XL using Tapatalk
    Smrtss1 is offline Cadillac Owners Member
    Automobile(s): '12 Escalade
    Feb 2017
    Chicago area
    45
    66
    Front is magnetic ride, rear is air shocks and if you have more than 50-60k chances are you need to replace everything. Check front for leaks on the strut, check rears for tear in the boots. If it’s riding stiff like you say it’s the shocks (mine did the same) and yes you can replace everything with passive struts or you can replace fronts with passive and rears with air ride. If you replace everything with standard struts you’ll throw a code and have a suspension light come on the dash which can be bypassed with wiring in a resistor, just google your year and type in “suspension bypass” or “suspension resistor” (on Amazon and ebay as well). The dash warning gets irritating after a while.
    I replaced everything with new gear from Arnott Industries, fronts I did a full assembly with spring and rear is just a replacement air strut. I couldn’t justify the extra cost for mag-ride struts when they go out in 50k miles
    Sent from my iPhone using Tapatalk
  5. #4
    007matman's Avatar
    Jun 2016
    372
    Not to argue but I'm pretty sure the rear is air shocks plus magnaride.
    The part numbers are different for the non-magnaride air shocks system (Z55 I think)
    If you have the Z95 package, the rear shocks have an electrical connection that allows the magnaride (otherwise, it would just have the compressor connection fitting).
    Here is the rear.
    ACDelco 580-1091 GM Original Equipment Rear Air Lift Shock Absorber Kit https://www.amazon.com/dp/B014RFETY6..._vFR4Cb8PWGBJ4
    Here are the fronts (unloaded)
    ACDelco 580-435 GM Original Equipment Front Shock Absorber https://www.amazon.com/dp/B00EDQ14DE..._NJR4CbCB7YFCR
    I have a '10 Esky Premium Luxury. Rears are a piece of cake. I have not done the fronts yet (they were new when we purchased the truck).
  6. #5
    996
    May 2019
    007matman - Thank you for your reply. So you sent both OE front and rear shocks in your link? Magneride front and air rear (or air+magneride rear)?
    Smrtss1 - I'll do some preliminary checks to see what is going on. We will most probably replace the whole system. How is your ride without the front magneride suspension? We are still on the OEM 22's. Also, is there a way to diagnose the actual air compressor?
    Thanks all.
  7. #6
    Feb 2017
    Chicago area
    45
    66
    Hard to tell the difference in the ride since my struts were wasted when I bought mine and it rode like a bulldozer. It got significantly better after I replaced everything even with lowering the rear to level it out.
  8. #7
    Feb 2017
    Chicago area
    45
    66
    Rears are not mag-ride. Electrical connection is for the BCM and compressor. Still has to be bypassed if running passive struts.
  9. #8
    007matman's Avatar
    Jun 2016
    372
    Quote Originally Posted by 996 View Post
    Thanks all.
    Yes. I went with these. I did use Arnott shocks on my Denali. Very happy with both.
    I wanted to keep it OEM. I've heard of people complaining of rough ride and 22's without it. I figured 50k is too short. However, if I do it myself it's cheaper than someone else doing it with bypassed system.
    It's really a personal choice. I figured if I was to buy one and find out the PO had bypassed the system I'd be mad.
  10. #9
    007matman's Avatar
    Jun 2016
    372
    Quote Originally Posted by Smrtss1 View Post
    So, if that is true why is the part number different?
  11. #10
    Feb 2017
    Chicago area
    45
    66
    Quote Originally Posted by 007matman View Post
    Suburban, EXT?
    Police package?
    Z71 package?
    Gm changes part numbers based on nothing but build date or because they changed manufacturers. I think they do it because they secretly hate parts people.
  12. #11
    007matman's Avatar
    Jun 2016
    372
    Suburban, EXT?
    Police package?
    Z71 package?
    The subject is Escalade.
    There are two packages.. Z55 and Z95 RPO codes.
    This is what I understand..
    If you have the 18" wheels, you likely have the Z55 package which includes what used to be called "Autoride" self-leveling (aka Air Ride) suspension. The 18" wheels have taller tires and in most cases the magnaride isn't really needed. In looking up a few articles it appears that the fronts are magnetically controlled (not the rear). So, your statement that the rear for this model is not magnaride would be correct.
    If you have the 22" wheels you likely have Magnaride Z95. GM did have an option early on to get the vehicle without magnaride but I believe by 2010 it was standard. They did this because customer complaints of a stiff ride (not enough sidewall). The articles I see indicate that the rear is magnetically controlled too.
    The part numbers are unique. This difference would explain the different part numbers for the rear on the two packages.
    There were many different options on these trucks and who knows what happened after the vehicle left the factory. Check the RPO code in your glovebox to confirm which package you have. It's not uncommon for a truck to get 22" wheels by the dealer as a dealer installed option.
  13. #12
    Feb 2017
    Chicago area
    45
    66
    I have a ‘12 Premium with Z95 code and 22” wheels. It DID NOT come with mag-ride rears.
    None of them came with electronically controlled magnetic ride rear struts. The electronics for the rear are for the strut to communicate with the BCM to control the compressor to fill or deflate the rear struts.
  14. #13
    Feb 2017
    Chicago area
    45
    66
    Re: 2010 Escalade - Very Rough Bouncy Ride - Solutions?
    Let me ask you this. Why do you need electronically controlled magnetic fluid in an air filled strut? You don’t.
  15. #14
    007matman's Avatar
    Jun 2016
    372
    Struts are on the front.. they are not air-filled.
    If you're talking about the Auto-ride shock, it's basically a conventional shock (oil-filled) with an air bladder "helper" spring built in that assists with leveling the ride.
    Magnaride uses magnets to automatically adjust the shock dampening based off of road conditions (via sensors). The system is capable of a crazy number of adjustments per second.
  16. #15
    Feb 2017
    Chicago area
    45
    66
    5 hours later and you’re still arguing.
    Rear is NOT MAGNARIDE. That is from 2 GM parts people, the parts manager, a service advisor and a service director. Plus days of searching online before I bought new rear struts a year and a half ago.
    Front struts are mag-ride
    Rears ARE NOT.
Similar Threads
  1. Bumpy/Bouncy ride in 2012 Escalade
    By jharding in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 06-06-18, 12:59 PM
  2. 2003 STS very bouncy
    By speedydog in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 11-23-14, 03:47 PM
  3. 2001 DTS bouncy bouncy is that normal?
    By Chickengas in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 05-13-06, 02:05 AM
  4. Sometimes the Best Solutions are the Obvious Solutions
    By stevehogan in forum Cadillac Catera and Cimarron Forum
    Last Post: 06-27-05, 08:13 AM
  5. Stiff and bouncy ride on my 02 escalade.
    By pf728 in forum Suspension, Brakes and Tires
    Last Post: 01-01-05, 06:26 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
