07' EXT Driver's Window Automatic Up/Down function
Results 1 to 7 of 7
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 07' EXT Driver's Window Automatic Up/Down function in Cadillac Escalade Forums; Hi there, I recently purchased a near perfect 07' EXT to replace my 05' with 335k miles. I really love ...
    icemann427 is offline Cadillac Owners Member
    Automobile(s): escalade ext
    Mar 2010
    25
    Hi there,
    I recently purchased a near perfect 07' EXT to replace my 05' with 335k miles. I really love it but was wondering if the automatic down driver's window function can be turned into an auto down and up function? Can that be done by replacing the switch with a newer one? Not sure the auto feature is in the switch, though. Thanks!
    Myrustlervxl is offline Cadillac Owners Member
    Aug 2018
    21
    Re: 07' EXT Driver's Window Automatic Up/Down function
    I have a 2011 ESV and I had to reprogram mine by holding the switch down all the way till it bottomed out and hold it for about two seconds and then hold the switch up so the window comes up and hold it for about two seconds that’s how I program mine but mine is an 11
    Sent from my iPhone using Tapatalk
    ckescaladeESV2k10 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac Escalade ESV Premium
    May 2018
    Huntington Beach, CA
    11
    On my 2010 ESv it has the up/ down automatic feature.
    You might need to reset the module. Roll the window down then roll it back up. Once up hold the up button for 10 seconds and it should go back to the auto up/ down feature.
  5. #4
    Mar 2010
    25
    Thank you! I will try that. I just figured the 07' was too old to have the down and up auto window function. Thanks, again!
  6. #5
    qudlatyz28 is offline Cadillac Owners Member
    Automobile(s): 2011 SRX, 2008 Escalade
    Feb 2019
    Phoeniz, AZ
    3
    Hey Icemann427,
    Did it work?
    I got 08 Escalade Base and was hoping that this would fix it, probably will just try it myself later on today.
  7. #6
    Feb 2019
    Phoeniz, AZ
    3
    It did not work. Figured I'd let you all know. I think the 08' is too old for that feature. I thought I had that in my 04' EXT, but I'm not 100% sure. But on the other hand, I thought the 08' would be more comfortable than the older one, and I have to tell you I am not impressed at all. I'm 6'4" and I had plenty of headroom in my 04' and I'm touching the headliner in the 08', very disappointed.
  8. #7
    Phoenixx's Avatar
    Phoenixx is offline Cadillac Owners Fanatic
    Automobile(s): 19 Escalade ESV Platinum 08 SRX N* 14 Escalade Platinum
    Jul 2016
    Canada
    443
    Quote Originally Posted by icemann427 View Post
    Hi there,
    There is only express down, no up for 07.
    Just quickly press and release the down button on the front drivers and passenger doors.
    Not sure on the conversion for the 07 08 for part 25924148 as it now shows discontinued.
    The 09-14 is 20835555 now is different size and connection.
Similar Threads
  1. 2010 SRX lost automatic window up and down passenger side only.
    By norman52 in forum Cadillac SRX Second Generation Forum (2010-2016)
    Last Post: 07-28-17, 12:38 PM
  2. Back window driver side window will not roll down from master control panel
    By grimacesp in forum 2008-2013 Cadillac CTS General Discussion
    Last Post: 07-05-16, 11:16 AM
  3. 07 ext sunroof won't work/keyless entry doesn't work/pass window won't go down help!!
    By 07escaladeext in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 02-23-12, 04:16 PM
  4. Power door lock non-function, heated seat non-function related?
    By Cy P in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 12-30-11, 10:07 AM
  5. Form Over Function, Or Function Over Form?
    By RLandis in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 12-20-07, 11:16 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
