2012 Escalade starting problems
Results 1 to 8 of 8
Cadillac Escalade, EXT and ESV Forum - 2007-2014 Discussion, 2012 Escalade starting problems in Cadillac Escalade Forums; Okay I have been searching the forums for this particular issue. Not sure if this is a common problem or ...
    motomaniac is online now Cadillac Owners Member
    Automobile(s): 2012 Escalade Platinum
    Apr 2012
    9
    Not sure if this is a common problem or not, however the past couple of days I would go out to my Escalade in attempts to start it with no luck. This is exactly whats going on: I insert key and turn, all the lights on the dash come on and the final key turn I get nothing. No clicks, no security lights and complete silence. So i turn it off, mess around with door locks (probably unrelated) and wait like 10 minutes and it cranks right up. I'll turn it off and in 2 minutes it will crank right back up, no problems.
    Anyone else have this issue or know the fix? The battery terminal cables are tight and not corroded either.
    Apr 2012
    9
    Re: 2012 Escalade starting problems
    Anybody??
    MrHolland's Avatar
    MrHolland is online now Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    6,294
    Sounds like a pass key fault. Have you tried other keys?
  5. #4
    pktrusty is offline Cadillac Owners Member
    Automobile(s): 2010 Escalade
    Apr 2018
    SLC., UT
    96
    I am not saying it is the battery cable but I had some electrical issues going on with my car. Changed the positive and negative cables even though they were tight and it went away.
  6. #5
    Apr 2012
    9
    Thanks for the reply's - Okay so this is what I did 10 minutes ago with spare key. Went out to vehicle, turn once all lights come on as normal, continue to turn and nothing. No noise no security lights, nothing. However, I noticed that when the automatic lights tuned off once I pulled the key out (about 20 seconds) I could go back and it cranked right up.
  7. #6
    Apr 2012
    9
    Any thoughts on what it might be?
  8. #7
    Phoenixx's Avatar
    Phoenixx is offline Cadillac Owners Fanatic
    Automobile(s): 19 Escalade ESV Platinum 08 SRX N* 14 Escalade Platinum
    Jul 2016
    Canada
    443
    I would say new ignition switch. Then a pass lock relearn.
  9. #8
    Apr 2012
    9
    thanks - I just purchased a new ignition switch and will see what happens
Similar Threads
  1. Looking to purchase a 2011-2012 Escalade....common problems to look out for?
    By iwinforthewin in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 10-21-16, 12:58 PM
  2. 2012 V starting problems...
    By Nichole0308 in forum 2009-2015 Cadillac CTS-V General Discussion
    Last Post: 06-12-14, 10:58 PM
  3. problems with starting on 08 cadillac escalade
    By BigDawg99 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 12-24-13, 12:38 PM
  4. Problems starting 2003 Cadillac Escalade
    By jakemcc1774 in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 09-04-13, 08:04 PM
  5. 1997 Deville Starting Problems and Sputtering Problems
    By SVO351 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 04-25-11, 10:06 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
