Is this true?
Results 1 to 4 of 4
Cadillac ELR Forum (2014-2016) Discussion, Is this true? in Past Cadillac Vehicle Discussion; I was reading the digital brochure that Greek300 nicely posted about. I was reading a little more carefully and the ...
    Deafsoundguy's Avatar
    Deafsoundguy is offline Cadillac Owners Member
    Automobile(s): 2016 ELR
    Mar 2019
    Portland OR
    89
    Is this true?
    I was reading the digital brochure that Greek300 nicely posted about. I was reading a little more carefully and the brochure states:
    "ACTIVE AERO GRILLE SHUTTERS
    Dynamic design. Active aero grille shutters automatically close at highway speeds to maximize aerodynamics and open at lower speeds when additional cooling may be required."
    Is that true? What part is actually closing? It seems like a solid one piece deal. Anyone know about that?
    If that was true, that would be pretty cool...
    Greek300 is offline Cadillac Owners Member
    Automobile(s): 2016 Cadillac ELR white
    Oct 2016
    Dallas Texas
    28
    Re: Is this true?
    ironically, I asked about this at the dealership and got a long blank stare so no idea...
    Mar 2019
    Portland OR
    89
    Re: Is this true?
    It is true after more research. It's mentioned many times regarding the ELR and many other GM products. It behind the grill so it's not like it becomes this layer of glass over the existing grill or something that plugs the small holes that are there from an outside view. The ELR already has a flush grill so I can't imagine how more that the active shutter behind the grill could make a difference but I'm not going to complain ! Here's from GM:
    "Aerodynamics play a crucial role in the design as airflow is managed to help the vehicle slip through the air with minimal drag. A flush front fascia and grille – with active shutters behind the grille opening – as well as tapered fascia corners, enable air to move easily around the car to reduce drag. In the rear, sharp edges and a carefully designed spoiler also manage airflow. An aggressive rake on the windshield and back glass help reduce turbulence and drag and contribute to ELR’s 0.305 coefficient of drag."
    here's a shot from someone with AGS from a CTS. You can see the shutters.
  5. #4
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (silver)
    Jan 2005
    California
    416
    Re: Is this true?
    It's the lower portion of the grille (below the bumper) that opens and closes. The shutters are behind the black plastic, so you probably wouldn't notice the difference unless you bend down and look inside when they're closed. It helps the car be more aerodynamic, and (I assume) allows it to keep the coolant warmer in cold weather.
Similar Threads
  1. custom, forged, or 6, true, wheel True Forged Custom Wheel GB 8/23-9/30
    By type911 in forum Group Purchases & Member Discounts
    Last Post: 09-11-09, 02:03 PM
  2. Corsa exhaust or true dual exhaust from vogue for my 3.6?
    By Devil_concours in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 05-19-04, 10:43 PM
  3. strange but true
    By bill1996 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 04-09-04, 07:58 PM
  4. New meaning to 'Drive in and pick up' (Funny/true/pictures)
    By Speedingpenguin in forum Community Lounge, Introductions and General Discussion
    Last Post: 04-04-04, 12:40 PM
  5. Old Cars True HP Ratings explained! N* vs Cad 500
    By Ultra Slow in forum Community Lounge, Introductions and General Discussion
    Last Post: 12-01-03, 09:05 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
