Extended storage of the vehicle
Results 1 to 3 of 3
Cadillac ELR Forum (2014-2016) Discussion, Extended storage of the vehicle in Past Cadillac Vehicle Discussion; I thought this subject was addressed in the manual, but can't seem to find it: Should the vehicle be left ...
    Typhoontye is offline Cadillac Owners Member
    May 2018
    34
    I thought this subject was addressed in the manual, but can't seem to find it: Should the vehicle be left plugged in for extended periods of storage? I know the answer is 'yes' for a few weeks. Also 'yes' if extreme ambient temperatures are expected. But not entirely sure what to do if the vehicle may not be driven for many months (in an insulated garage environment....not too hot/cold). One thought is to set the charging program to only 'charge' for an hour or so a day. Not sure if that accomplishes anything. Any thoughts?
    David
    2016 Radiant Silver ELR
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (silver)
    Jan 2005
    California
    411
    Re: Extended storage of the vehicle
    I don't see any reference to it in the ELR manual, either. This thread from the Volt Forum may be helpful, though:
    https://gm-volt.com/forum/showthread...986#post209986
    I don't think charging for an hour a day would keep the 12v battery charged if the high voltage battery starts out/gets full (i.e. it wouldn't need to charge at all, so it wouldn't wake up to charge the 12v battery). Their suggestion about starting with an empty battery and slowly letting the car charge back up should work, but if it goes long enough that the battery is fully charged, it might eventually allow the 12v battery to die.
    I'd probably be most comfortable leaving the car half charged and putting an AGM battery tender on the disconnected 12 volt battery in the trunk. That way, you know for sure that the 12v battery won't be depleted and the car won't be trying to do anything you don't expect while you're gone. Note, too, the reference on page 285 to lifting the car for extended storage to protect your tires. Consider fuel stabilizer, also.
    May 2018
    34
    Thanks Reciprocity,
    Good points. I've left already but will have a buddy go over and disconnect the main charging cord (240V) and the negative terminal for the 12V Battery. Probably my best action plan at this point.
    I made sure I had non-ethanol gas through out the fuel system before we left. I think I should be ok with that for at least four months. Should have lifted the car a bit but ran out of time. Plus, when the wife returns occasionally she will need to drive the vehicle. Optionally, I understand increasing tire pressure can also help keep the tires in round, but didn't do that either.
    Appreciate the reply!
    David
Read about Lincoln | Buick | Genesis | Kia Forte Forum
