Driver ABS shorted 2006 DTS
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By danog
Cadillac DTS Forum - 2006 through 2012 Discussion, Driver ABS shorted 2006 DTS in Past Cadillac Vehicle Discussion; So I kept getting a sporadic abs codes primary when it rains. Codes were C0561 and C0035. I removed the ...
    stephenp101's Avatar
    stephenp101 is online now Cadillac Owners Member
    Automobile(s): 2006 Cadillac DTS
    Dec 2018
    Ogdensburg NY
    33
    31
    So I kept getting a sporadic abs codes primary when it rains. Codes were C0561 and C0035. I removed the wheel and did the jiggle test and confirmed its the wires running up into the engine area. Also to note someone had been working on this area before I bought the car because I can see where wires have been heat shrinked. Where do these wires come out? DO they connect to the abs module or? As far as I can see is around the EGR. I want to replace the wires in whole, advice? Thanks for the comments.
    danog is online now Cadillac Owners Enthusiast
    Automobile(s): 1936 cadillac 11 DTS 11 DTS
    Nov 2011
    685
    Re: Driver ABS shorted 2006 DTS
    Omac and stephenp101 like this.
    Dec 2018
    Ogdensburg NY
    33
    31
    Quote Originally Posted by danog View Post
    ECMB
    Wheel Speed sensor
    While car is running is that a constant 5 volt reference? Do you know the good resistance values of the hot/ground wires? So I am assuming If I want to replace the whole wire from the ECMB to the wheel sensor, will just have to trace them, Though I could only trace it down below the EGR area.
  5. #4
    Dec 2018
    Ogdensburg NY
    33
    31
    Found the short, it was at the point where it connects to the body. Cut the rubber back maybe 3 inches. butt connected it back and heat shrink wrapped it. abs light gone. I guess if it happens again I will solder it back or just buy a new oem harness. Note: Accidentally posted the wrong wheel harness but the pictures might help someone someday.
Similar Threads
  1. Service Stability System light C0286 ABS Indicator Lamp Circuit Shorted to Battery
    By sosatime in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 08-21-13, 07:42 AM
  2. ABS / BRAKE / TRACTION CONTROL shorted on...
    By moyo25 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 08-02-11, 11:13 PM
  3. ABS / BRAKE / TRACTION CONTROL shorted on...
    By moyo25 in forum Cadillac DTS Forum - 2006 through 2012
    Last Post: 07-05-11, 11:54 AM
  4. Service Stability System light C0286 ABS Indicator Lamp Circuit Shorted to Battery
    By Wafflez in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 03-22-07, 08:06 AM
  5. Service Stability System code C0286 - ABS Indicator Lamp Circuit Shorted to Battery
    Last Post: 03-10-07, 12:36 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
