Rear Passenger Side Valve Cover Wet ???
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac DTS Forum - 2006 through 2012 Discussion, Rear Passenger Side Valve Cover Wet ??? in Past Cadillac Vehicle Discussion; And we are low on power steering fluid, is this common anything in particular to look for - known problem ...
    Pete1996 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, 1996 STS - RIP
    Aug 2009
    CT - USA
    267
    to look for - known problem areas?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,891
    Re: Rear Passenger Side Valve Cover Wet ???
    Either the power steering pump drive shaft seal or pressure line.... or the dirty air line/connectors for the PCV system. MAYBE a couple of loose cam cover bolts at the cam drive sprocket (passenger) end.
    Pete1996 likes this.
Similar Threads
  1. Valve cover gasket - Rear valve cover gasket Is there a difference?
    By UGABrodel in forum Cadillac DTS Forum - 2006 through 2012
    Last Post: 02-28-18, 09:45 AM
  2. Wet Wet Wet
    By cleancarz in forum 2008-2013 Cadillac CTS General Discussion
    Last Post: 05-01-14, 12:54 PM
  3. 2004 SRX wet jack compartment and wet back passenger floor
    By mrs_big in forum Cadillac SRX First Generation Forum - 2004 - 2009
    Last Post: 01-19-13, 09:47 AM
  4. Wet passenger side rear floor
    By justfishing41 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-30-08, 04:46 PM
  5. Wet carpet on passenger side rear
    By 2000ForrestGrnCatty in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 05-17-08, 08:32 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
