ABS light and traction control light
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By footbrake
Cadillac DTS Forum - 2006 through 2012 Discussion, ABS light and traction control light in Past Cadillac Vehicle Discussion; Hello, I have a Cadillac DTS with 100K miles. Its been raining for 10 straight days here. Today my ABS ...
    mtr18103 is offline Cadillac Owners Member
    Automobile(s): 1991 Deville
    Jul 2016
    51
    Its been raining for 10 straight days here. Today my ABS light came on at low speed when braking. The traction/stability light is also on with it. I assume they are both on due to an ABS sensor.
    I restarted the car later and it went away for 50 miles, but came back on when braking at low speeds later. So it is intermittent. I see a TB for Cadillac's on Wheel sensor corrosion and this makes sense. It was raining all day while driving it.
    How do I tell which sensor is bad? I have engine scanners but they don't read ABS codes. I saw something about disconnecting the connector to the sensor and rotating the tires. Then measuring AC millivolts. Is there another way to see which one is giving me trouble?
    Thank you
    footbrake's Avatar
    footbrake is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS 4.6,2005 Jaguar X-Type
    Nov 2014
    Buffalo,NY
    139
    Re: ABS light and traction control light
    My mechanics scanner told him exactly which wheel it was on. Take it to someone that has a better scanner than you're using.
    Omac likes this.
Similar Threads
  1. No ABS Data, Service Suspension System, Brake Light ABS Light, Traction Control Light
    By asilverblazer in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 07-10-13, 02:04 PM
  2. '04 ESV ABS & Traction Control lights-dealer suggests $1100 BPMV and $550 ABS module
    By toptiger in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 09-03-10, 08:15 AM
  3. Traction Control Light and ABS light
    By fron3 in forum Cadillac Catera and Cimarron Forum
    Last Post: 05-25-08, 01:00 AM
  4. HELP!!! ABS light and traction control light come on when shifting from park.
    By Jcarter1986 in forum Cadillac Catera and Cimarron Forum
    Last Post: 09-14-05, 02:41 AM
  5. Traction Control Light ABS Light Brake Light On
    By rlklawyer in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 05-17-05, 11:01 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
