timing chain tools
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By KowalskiTG
Cadillac DTS Forum - 2006 through 2012 Discussion, timing chain tools in Past Cadillac Vehicle Discussion; i'm looking to preemptively replace the timing chain set on my 2007 DTS, I bought the dealer kent-moore J44212(cam plates), ...
    KowalskiTG's Avatar
    KowalskiTG is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS
    May 2018
    Bethlehem, Pa
    115
    timing chain tools
    i'm looking to preemptively replace the timing chain set on my 2007 DTS, I bought the dealer kent-moore J44212(cam plates), J39946(crank socket), and J44214(flywheel holder) on ebay from a closed local dealer.
    Other than a harmonic balancer puller+installer, and water pump pulley tool, are there any other special tools I need to do this correctly, and what do I need to buy other than the chain kit, oil pump, timing cover gasket and seal, valve cover gaskets, and the w/p cam seal if I want to do it the right way the first time?
    KowalskiTG's Avatar
    May 2018
    Bethlehem, Pa
    115
    Re: timing chain tools
    Northstar tools came in! I also bought some 3-jaw pullers and the puller kit for the water pump pulley. Just ordered gaskets, next gonna order the chains and guides over the weekend
    CadillacLuke24 and Omac like this.
    StephanBlake83 is offline Cadillac Owners Member
    Automobile(s): 2001,2006 DTS
    Mar 2017
    35
    80
    Where did you buy cam holder tools? I had a link and lost it lol. Need some of those, thanks!
  5. #4
    KowalskiTG's Avatar
    May 2018
    Bethlehem, Pa
    115
    guy I bought them from for $50 only had 1 set but this guy in ohio has them for $63. i paid just under 100 for everything
    https://www.ebay.com/itm/Kent-Moore-...pe!18018!US!-1
    there's also a kit for ~160$ on amazon that comes with the crank socket, cam plates, and some other stuff I have no idea what they do (i probably would've bought them if I did)
    https://www.amazon.com/OTC-6686-Cam-...r=8-1-fkmrnull
    edit: other tools in amazon kit are a "secondary drive sprocket fixture" and "timing chain retention tools" I went through the FSM and didn't see them used for the timing chain job so i'm assuming I won't need them, maybe the retention tools are to hold the chain if you're just replacing guides or something. not sure about the secondary drive sprocket fixture though
Similar Threads
  1. Timing chain seems tight.... after random chain grinding in the front of engine??????
    By dylankzmsk in forum V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT
    Last Post: 05-08-18, 08:58 PM
  2. 2.0T timing belt or timing chain?
    By mdoaw12i in forum Cadillac ATS General Discussion Forum
    Last Post: 08-27-14, 10:29 PM
  3. Commercial Scan Tools versus Dealer Scan Tools
    By DevilleNut in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 06-03-14, 09:52 PM
  4. need help 07 2.8 timing cover removal and timing chain replacement
    By tom70 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-03-13, 06:00 PM
  5. Timing chain issue, not lining up? stretched chain possibly?
    By devill.dude in forum Northstar Engines and System Technical Discussion
    Last Post: 12-09-12, 10:48 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
