Deville digital temperature gauge inop
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Deville digital temperature gauge inop in Past Cadillac Vehicle Discussion; Greetings, fellow techs and Cadillac owners. I have an 02 Deville and the temp gauge(digital) is inop. I replaced the ...
    GabboTheGreat's Avatar
    GabboTheGreat is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Oct 2015
    34
    1
    Greetings, fellow techs and Cadillac owners. I have an 02 Deville and the temp gauge(digital) is inop. I replaced the t-stat and temp sensor with no avail. Does anyone know what else to check? It has 190K and my next move is to replace the level sensor. Thank you
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    7,274
    The engine coolant doesn't register or reads incorrectly?
    Well the water pump nor the thermostat has anything to do with that. The ECT or wiring is probably bad. The ECT is a real sob to get to, rear head over trans and below the crossover.
    71
    85,733
    Re: Deville digital temperature gauge inop
    have you pulled the DTC's?
  5. #4
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,875
    Coolant level sensor (in the surge tank) has nothing to do with gauge function.
    Here's the ECT sender location.
Read about Lincoln | Buick | Genesis | Kia Forte Forum
