2000 DeVille Dirty Air Tube
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DeVille Dirty Air Tube in Past Cadillac Vehicle Discussion; I have a 2000 DeVille and my dirty air tube for my pcv valve is broken where it meets the ...
    ironeaglejrc is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac DeVille
    Dec 2018
    Glendale AZ
    4
    I have a 2000 DeVille and my dirty air tube for my pcv valve is broken where it meets the intake manifold. What can I use to fix this problem with out getting a new one? It is creating an vaccum leak and getting annoying. Please help this my first cadillac.
    jmf1964 is online now Cadillac Owners Fanatic
    Automobile(s): 2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
    Jun 2009
    boston mass or thereabouts
    55
    486
    Re: 2000 DeVille Dirty Air Tube
    Cut out the damaged section and replace it with some 3/8" fuel line hose.
    71
    85,739
    Don't think that will work (if the OP is talking about the elbow - part #570). You can probably find an elbow at the Help rack at most parts stores. Otherwise, get one from most any GM dealer parts dept. Even there, it can't be more than a few bucks.
  5. #4
    Jun 2009
    55
    486
    on my 04, which is a little different, the rubber coupling on the other end split, i replaced it with a piece of fuel line hose. I had to replace the elbow (570) several years ago, the mechanic said he was able to get at it with long needle nose pliers.
  6. #5
    littlewolf is offline Cadillac Owners Member
    Automobile(s): 2003 deville
    May 2011
    10
    The elbow cracked on my 2003 and caused a p0174 code. I put, or more like stuffed a surgical glove around it until a time when I can make the proper repair. When the car is running, the vacuum pulls in the glove to seal the leak. Had it on there for two months now and the code is gone. Helped me pass my emissions inspection.
Similar Threads
  1. Dirty Dirty Dirty
    By alisha_c in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 04-24-17, 01:49 PM
  2. Dirty Air tube replaced - engine now dies at idle??
    By Piney in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 05-24-15, 06:28 PM
  3. Dirty Air Intake Tube Broke, need P/N
    By stsscott in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-12-15, 05:24 PM
  4. 02 deville vacuum leak pcv dirty air tube
    By spunky in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 01-11-15, 03:49 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
