'89 Deville tire pressures?
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '89 Deville tire pressures? in Past Cadillac Vehicle Discussion; Hi all, I have recently purchased an '89 Deville in great condition. It pulls a bit to the right, so ...
    caramihn is offline Cadillac Owners Member
    Apr 2019
    3
    Hi all,
    I have recently purchased an '89 Deville in great condition. It pulls a bit to the right, so I wanted to make sure all the tires are at their correct pressures. The sticker on the door is missing, can anyone kindly tell me what the recommended pressures are for all four wheels?
    Discount Tire's Avatar
    Discount Tire is offline Authorized Vendor
    Apr 2017
    66
    Re: '89 Deville tire pressures?
    The O.E. tire pressure for the O.E. tires for your 89 would be 30 PSI.
    What size tires are on the car? If you're running something other than O.E. sizing then the pressure may need to be adjusted depending on the load index and the construction of the tire.
    Low Prices! More Choices! Trusted Experts!
    At The Store: discounttire.com[/U]
    To Your Door: discounttiredirect.com
    Useful Links:
    91FleetwoodCoupe's Avatar
    91FleetwoodCoupe is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Fleetwood Coupe (& 1990 Lincoln LSC SE)
    Oct 2016
    29
    321
    They call for 30 but being a big heavy car I do 35.
  5. #4
    Apr 2019
    3
    Quote Originally Posted by Discount Tire View Post
    215/70R15, I believe these are OE. Thank you for your quick reply
  6. #5
    Apr 2017
    66
    I show 205/70R-15 as O.E. sizing - which brand and tire model is installed on the vehicle?
    Useful Links:
  7. #6
    basscatt's Avatar
    basscatt is online now Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,296
    Quote Originally Posted by 91FleetwoodCoupe View Post
    you gain nothing by over inflating the tires -
    you MIGHT actually shorten the life of the tires -
    not to mention giving a harsher ride -
    1969byrdman likes this.
  8. #7
    1969byrdman's Avatar
    1969byrdman is online now US Coast Guard: Semper Paratus
    Automobile(s): 2003 DeVille base, 145K miles
    May 2014
    Van Zandt County, Texas
    71
    3,753
    Quote Originally Posted by basscatt View Post
    yup. you'll have premature wear in the middle of the tread.
  9. #8
    Apr 2019
    3
    You're right, I guess the previous owner put slightly wider tires. They're Yoko's in the front and Goodyear's in the back. I have them at 32 psi currently
  10. #9
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,863
    Tire tread wear diagnosis..................
    The manufacturer's recommended cold inflation pressures - on the driver's door sticker and/or owner's manual - are developed for THAT car/tire OEM specification. Increasing pressure by more than 1 - 2 psi only contributes to accelerated wear - it has NO effect on a "heavy" car or weight carrying abilities, but contributes to a harsher ride and increases suspension over-reaction to road surface faults.
Similar Threads
  1. Recommended Tire Pressures
    By 05STSWOW in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 05-30-15, 12:53 PM
  2. 2003 DeVille - I've Lost my Tire Pressures!
    By 2dfx in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 07-07-14, 08:16 PM
  3. Tire pressures
    By wht2000 in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 08-08-05, 01:48 PM
  4. Deville Tire Pressures
    By FLEALAMI in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 06-17-05, 03:47 PM
  5. Tire Pressures?
    By BackMarker in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 09-26-04, 06:54 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
