Flushing coolant on a 2002 deville
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Flushing coolant on a 2002 deville in Past Cadillac Vehicle Discussion; Is there anything special I need to know. I already have 2 gallons of pre-mixed dexcool. Is that gonna be ...
    Tedtruck is offline Cadillac Owners Member
    Dec 2018
    3
    Is there anything special I need to know. I already have 2 gallons of pre-mixed dexcool. Is that gonna be enough. Thanks in advance guys you always help meout.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,906
    Re: Flushing coolant on a 2002 devile.
    If you use a pressure/vacuum exchange machine you'll need just over 12 quarts to do a complete job. A simple drain and fill - your 8 quarts, should be about enough.
    Just make sure to do a correct exchange, fill, and purge, otherwise you'll have nagging problems with temporary overheat events for a while.
    Pre-mix coolant is highway robbery. At just over $15 a gallon for pre-mix you're paying over $7.50 for 2 quarts of water.
    Read up on your cooling system in the stickies in the Engines; Northstar forum.
    71
    85,739
    Re: Flushing coolant on a 2002 deville
    Quote Originally Posted by Tedtruck View Post
    You'll have some left over.
Similar Threads
  1. Coolant flushing
    By Killercavi in forum Cadillac Catera and Cimarron Forum
    Last Post: 06-21-06, 07:16 PM
  2. Coolant Flushing Pros/Cons?
    By Trench in forum Northstar Engines and System Technical Discussion
    Last Post: 11-07-05, 01:29 PM
  3. Can anything go wrong/Flushing coolant?
    By MARK2995 in forum HT4100 4.1, 4.5, 4.9
    Last Post: 10-08-05, 04:30 PM
  4. Coolant Flushing Mistake? ?
    By MARK2995 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 10-06-05, 05:31 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
