'93 Sixty Special - Blower motor always on full speed
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '93 Sixty Special - Blower motor always on full speed in Past Cadillac Vehicle Discussion; Hey Guys, when starting the car after a long winter the blower motor started to blow at full speed no ...
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    354
    Hey Guys,
    when starting the car after a long winter the blower motor started to blow at full speed no matter what is being set at the display. The blower motor runs even when it's set to 'Off'. Also I noticed a smell as if something was burnt.
    I've worked through the FSM and checked with Chart 3 "improper blower speed" and checked the voltage at the 4-pin connector to the blower motor (PIN B) for voltage. That's the pin that is supposed to provide a regulated voltage from the BCM. I don't quite know what voltage is what blower level but since I got 14.8V no matter the setting I guess that's the reason the blower motor runs at full speed.
    The next check from the FSM is supposed to be this:
    "Check Voltage from BCM Connector C1 PIN A9 to GROUND (Backprobe)"
    I do know where the BCM is located - but how am i supposed to check the voltage while the connector is not plugged in?
    Do you guys know any other location where i might get a hold of the BCM Connector or can you offer some additional insight into the issue?
    From what it looks like the error seems to be with the BCM - but I do not understand how the smell of burnt electrical parts gets from the BCM into the air vents. Each time I start the car and plug in the fuse for the blower motor I get a "fresh" breeze of that smell. So the burnt stuff should be somewhere wihtin the air vents, right?
    Thanks!
    sefiro's Avatar
    sefiro is offline Cadillac Owners Enthusiast
    Automobile(s): 92 Fleetwood 2dr cpe - FWD, 96 Seville SLS, 02 Seville
    Jan 2007
    605
    Re: '93 Sixty Special - Blower motor always on full speed
    Needle probe through the wire sheathing or a back probe inserted into the backside of the harness that makes contact with the metal connector
    Harry Yarnell is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 eldorado,2008 DTS,2005 XLR, '96 eldo,'95 eldo,' 89 eldo,'78 eldo,'11CTS-V
    Dec 2004
    perryman, MD
    75
    1,462
    Save yourself some grief; the blower motor controller module is shot. Period.
    Sits on top of the A/C plenum next to the blower motor.
    I've got good (tested) modules for $38 postpaid.
  5. #4
    DReffects's Avatar
    May 2013
    Germany
    354
    Quote Originally Posted by sefiro View Post
    I was afraid of that because i do not want to damage the waterproofing.
    I'll try to get needle probes asap
    Quote Originally Posted by Harry Yarnell View Post
    That would explain the bad smell when the blower is activated. Are you certain? I am wondering because the disconnected 4-pin connector produced a voltage WAY OFF the diagnose sheet. In low setting it should be ~3V and I got 14.8V
    Or are those volts only measureable if the connector is connected to the blower motor controller?
    Can you ship to Germany?
  6. #5
    basscatt's Avatar
    basscatt is online now Master of the Dark Art of Diagnostics
    Feb 2004
    Minnesota
    67
    18,440
  7. #6
    Delux68 is offline Cadillac Owners Member
    Automobile(s): None
    Jun 2014
    40
    1
    I just bought a 93 sedan deville that seems to only blow all the way high, on every setting except low. Could that be my problem as well?
  8. #7
    DReffects's Avatar
    May 2013
    Germany
    354
    Quote Originally Posted by basscatt View Post
    That's superb. Nothing makes me more happy than a confirmed error that can be fixed I'll remove the module today.
  9. #8
    DReffects's Avatar
    May 2013
    Germany
    354
    Well, you guys were absolutely right, thanks for the spot on diagnosis!
    Since my fuse housings are a wreck from the previous owner I did not even had to remove the fuse panel - just move it to the side a bit and the module came right out.
    It looks and smells burnt:
    Of course I am intersted in the root issue behind this module failing so spectacularly. Could there be a different reason besides old age for the module to go bad?
    Also, can this module be replaced by the newer version with the same connectors from a 1994 deville?
    The newer models have exactly the same connectors and overall size but a enclosed module on the back instead of an open circuitry:
    https://i.ebayimg.com/images/g/Su4AA...-R/s-l1600.jpg
  10. #9
    Dec 2004
    perryman, MD
    75
    1,462
    Yes, the module from a '94 will work.
    Fuse panel?
  11. #10
    DReffects's Avatar
    May 2013
    Germany
    354
    Fuse panel?
    Sorry, just saw that the '94 module does not look any different. I mean a module like this: Same connectors and layout but different "stuff" on the inside:
    Fuse panel:
    was this meant as a comment to the root issue behind the module failing?
    I've checked all fuses. They look fine.
  12. #11
    Dec 2004
    perryman, MD
    75
    1,462
    The '94 looks stock; your bad one is a replacement.
    If the '94 is good, then it'll work.
  13. #12
    DReffects's Avatar
    May 2013
    Germany
    354
    Hmm I keep going back in my mind to the cause of the failure.... The diagram shows that the BCM should supply a control voltage between 0 and 5 V:
    Yet my readings at 1A9 / B (Yellow) were 14.8V when the connector was NOT connected to the Power Module.
    It also did not change when switching through the different blower speeds.
    So is it possible that the Power Module only failed due to a input control voltage that was way to high?
    Or are the 0-5V only measureable when backprobing with the connected power module?
    Edit:
    I took apart the module. Besides a few soldering points that looked rather old one major component failed in the power module: a resistor
    Behind the Gold/Gold/Green/Brown resistor is a totally wrecked other one.
    I've remove both resistors but due to the decayed state i cannot figure out what kind of resistor was sitting there.
    From the layout of the circuit board it looks like the failed resistor was directly connected to the hot 12V wire?
    All other components seem to be just fine. Does anyone know what kind of resistor goes there?
  14. #13
    sefiro's Avatar
    Jan 2007
    605
    Clean and inspect the board.. Old stds would have the component spec written on the board to aid the assembler.
  15. #14
    DReffects's Avatar
    May 2013
    Germany
    354
    The area beneath the resistor is beyond cleaning the contacts on the rear are fine but even for the non-burnt resistor there are no markings
  16. #15
    Padgett's Avatar
    Padgett is offline Cadillac Owners Connoisseur
    Automobile(s): '11 CTSC & several other cars.
    Sep 2018
    Orlando
    1,043
    Common happening on GM cars with ATC in the 80s-90s. Either fail open or on full. I have a stack of them.
Similar Threads
  1. Que: What's so special about the " Sixty special"???
    By fabchef in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 08-21-17, 06:03 PM
  2. Will 1993 Sixty Special Wheels fit my 1992 Cadillac Fleetwood Sixty Special?
    By tajohnmd in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 09-11-13, 03:36 PM
  3. '93 Sixty Special / 90-92 Fleetwood / '93 Deville Overhead Console
    By DReffects in forum Fleetwood Parts For Sale
    Last Post: 07-03-13, 05:12 PM
  4. overall..better vehicle between 1990 Sixty Special and 1993 Sixty Special?
    By keumnam in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 07-23-11, 07:05 PM
  5. '93 deVille compared to '93 Sixty Special
    By Sandy in forum Cadillac DeVille 1985 to 2005 including:
    Last Post: 05-02-04, 10:17 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
