2005 Deville ignition coil
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2005 Deville ignition coil in Past Cadillac Vehicle Discussion; here is a two part question: Should I replace just the weak coils or replace them all? Also, the aftermarket ...
    glenpointe is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Performance, 2005 DTS
    May 2014
    None listed
    61
    Should I replace just the weak coils or replace them all? Also, the aftermarket coils are 50% less than Delphi coils. Should I go with the aftermarket? About $125 in savings for 8 coils.
    71
    85,813
    Re: 2005 Deville ignition coil
    I'd only replace the ones that failed.
    Northstars don't seem to like anything but OEM plugs. I've never heard anything like that about coils, but I'd stay away from Autozone.
    GrandpaKen is offline Cadillac Owners Member
    Automobile(s): 2005 Deville
    Jun 2016
    69
    11
    I had a miss on cylinder 1 and opted to replace both banks with Delphi from Amazon for about $120 each. I also didn't know if the plugs were ever changed so I swapped those out too. Total was $300 and the car should be good for another 120k miles. Total time was about 1 1/2 hours for the back and 20 minutes for the front. If the miss was on the front I might have just replaced the one coil but with the work required to get at the back bank I decided it wasn't worth it to just replace the bad one.
  5. #4
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    53
    893
    Quote Originally Posted by GrandpaKen View Post
    I’m pretty sure the 2005 doesn’t use cassettes, but has individual coils.
  6. #5
    71
    85,813
    The cassette was used from 2000-2003.
  7. #6
    PFMDTS is offline Cadillac Owners Member
    Automobile(s): 2005 Deville DTS
    Nov 2018
    Elmhurst, Il.
    15
    I took a slightly different approach. I replaced all the spark plugs with OEM and changed the rear bank coils saving them as spares.
    I used the Delphi set purchased from Rock Auto. I had around 97K on my DTS and the plugs while burning well did need to be changed.
  8. #7
    jmf1964 is online now Cadillac Owners Fanatic
    Automobile(s): 2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
    Jun 2009
    boston mass or thereabouts
    55
    499
    Same here, I got the coils, Delphi, 2 banks of 4 with wire harnesses and brackets, from amazon for $114 each. But the skip in my motor was caused by a bad head gasket and did not go away, but the coils went on the new motor so it wasn't a complete waste.
    Also, be careful taking the old coils out. on mine 3 of them all in the back, the rubber insulator was left behind on the plug, a real pita to get out without the right tool.
  9. #8
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    65,205
    Quote Originally Posted by jmf1964 View Post
    That statement is support for using silicone dielectric ignition grease in the new coil tip boots. Dirt cheap at any parts store.
  10. #9
    Caddy-EaRL's Avatar
    Apr 2013
    Ky
    53
    893
    Quote Originally Posted by Submariner409 View Post
    It’s more likely that the so called “normal” oil seepage swelled the rubber. I’ve seen this to many times to count, not just on northstars. Which is why I always tell people when changing plugs and they see oil, that’s it’s not “normal” and the tube seals need to be changed. While so many others here tell people that the oil in the tube seal is “normal”, not to worry about it.
  11. #10
    71
    85,813
    Maybe common is a better choice of words than "normal".
  12. #11
    Feb 2006
    79
    65,205
    ........ and in most cases the small amount of oil in the plug well(s) accumulated over more than 100,000 miles and a lot of years. Maybe not "normal", but not uncommon.
    Because changing the spark plugs in a Northstar is such a bitch, few people regularly pull a plug or two to read them. Changing the spark plug well seals in the cam covers is also one hell of a tedious job.
    See those 8 O-rings? Plug well seals.
Similar Threads
  1. Ignition Coil and Coil Wire fried
    By Caddyshack95 in forum RWD 19xx-1984 DeVille and Fleetwood,
    1985-1996 Fleetwood and Brougham Forum
    Last Post: 01-10-18, 04:22 PM
  2. 2005 STS V8 AWD ignition coil pack
    By Mickjagger5 in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 07-15-14, 01:24 PM
  3. Ignition Coil Replacement 2005 STS 3.6
    By mdmings517 in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 08-01-13, 01:23 PM
  4. 3.2L Ignition Coil Wire Diagram Needed for MSD Ignition
    By 03KYCTS in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 03-19-12, 11:29 PM
  5. Ignition coil or ignition module ?
    By jert in forum Northstar Engines and System Technical Discussion
    Last Post: 06-22-03, 05:49 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
