Xm radio not working all of a sudden.
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Xm radio not working all of a sudden. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Xm radio been working for a couple years. All of a sudden I am just getting "No Signal" message. Tried ...
    mrum69 is offline Cadillac Owners Member
    Automobile(s): 2006 CTS
    Jul 2015
    62
    7
    Xm radio been working for a couple years. All of a sudden I am just getting "No Signal" message. Tried refreshing with XM and no luck. Disconnected battery to reset radio no luck. Anybody have any idea's?
    RyanY's Avatar
    RyanY is online now Cadillac Owners Fanatic
    Automobile(s): 2007 CTS 3.6 >120k miles
    Aug 2016
    South Carolina
    46
    305
    Re: Xm radio not working all of a sudden.
    I havent had any problems with the Cadillac but had two separate issues with my Honda XM. First time was a bad xm module...replaced under warranty. Second time was corrosion around the antenna that caused a short. The antenna is easy to check. Just remove the rear dome light and pull the headliner down far enough to access the screws, and then remove the antenna. Visual inspection may reveal issues (but this is not conclusive). If antenna appears fine, check the mount/connection and move on. The module is under the rear shelf cover...kind of a pain to access and no way to test DIY that I am aware of. Testing the module may be best left to dealer or audio shop, unless you just plan to replace and hope for the best.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    40
    9,714
    I believe the OnStar module uses the same raw antenna plug. Raw meaning you have to remove the plastic part of the plug and just use the actual metal connection.
    However, the OnStar module is located on the passenger side of the trunk. The very opposite side of the audio amp. So getting the OnStar cable and XM module in the same area for testing will be a bitch.
    I did replace the roof mount antenna on my CTS to a better looking antenna many years ago. I even painted it to match the color of my CTS. I had to use the OnStar's antenna cable to connect to my XM module. I can't remember why though.
    KOT
    Argent likes this.
  5. #4
    Jul 2015
    62
    7
    Do you where the XM module is located?
  6. #5
    Jul 2015
    62
    7
    Onstar works but still no XM.
  7. #6
    Apr 2009
    Ledyard, CT
    40
    9,714
    I just found this video and it makes sense. Although for your case it may still be the issue, even with you trying the OnStar as well.
    https://www.youtube.com/watch?v=pkf8caMn9JI
    KOT
    Argent likes this.
  8. #7
    Jul 2015
    62
    7
    Thanks alot for the help. Gonna give it a shot.
Similar Threads
  1. "Engine Power Reduced" All of a sudden and all these errors appeared
    By shaikup in forum Cadillac STS-V Series Forum
    Last Post: 05-07-15, 10:35 AM
  2. windows stopped working all of a sudden! Pleaseeee Help!
    By ctsbboy in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 10-02-13, 11:54 AM
  3. XM Radio: No XM Signal. XM Cust Support Says it's the Wire
    By MamaKin1534 in forum Cadillac STS Forum - 2005 through 2012
    Last Post: 01-07-13, 09:48 PM
  4. XM Radio or XM Radio not:
    By Gary Wells in forum Community Lounge, Introductions and General Discussion
    Last Post: 10-29-09, 11:20 PM
  5. XM Radio in NON XM equipped Radio
    By PrepJim in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 05-01-08, 02:29 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
