Air Condition Recharging
Results 1 to 4 of 4
Cadillac Catera and Cimarron Forum Discussion, Air Condition Recharging in Past Cadillac Vehicle Discussion; How do you recharge the ac. Mine is working ok, but I think it could be better. I can not ...
    overplayed's Avatar
    overplayed is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Catera
    Nov 2004
    VA
    182
    be better. I can not find the info in the service manual.
    Jeff
    05z71clunker is offline Cadillac Owners Member
    Automobile(s): 1998 Catera
    Apr 2006
    23
    Re: Air Condition Recharging
    you can get all you need at Wal-Mart. 1 can of freon " 134a " and they even have a cheat gauge with hose to load the gas ( instructions on back of box ). Pretty simple task to do. Just keep in mind that more gas/freon doesn't always mean cooler air. You have to keep it in the appropriate range as far as pressure. Should run around 35-40psi on low side. Low side is the bigger line that will be cold and wet with condesation.....or should be cold and wet. Just find the connection fitting on that line and connect gauge. If pressure is running to low, then screw on can of freon and slowly ad to system. Don't force froen into system. Just give a couple shots and keep checking gauge. Continue untill pressure is in acceptable range.
    overplayed's Avatar
    Nov 2004
    VA
    182
    Where is the connection for adding freon and checking pressure? Is it the valve just above the brake fluid reservoir?
  5. #4
    overplayed's Avatar
    Nov 2004
    VA
    182
    Does anyone know where to add the freon and or check the pressure?
Read about Lincoln | Buick | Genesis | Kia Forte Forum
